Subject: Re: Multiple IOCs on a remote server
To: Abdalla Ahmad <[email protected]>
Date: Tue, 21 Dec 2021 00:07:43 -0800
The following repo may help you
HTH,
Han
On Mon, Dec 20, 2021 at 23:44 Abdalla Ahmad via Tech-talk <[email protected]> wrote:
I think you need to setup UDP broadcasting on the host, see this article: https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
P.S.: For some reason, I had to manually set the "$addr" and "$bcast" variables, they were not working for me.
Best Regards,
Abdalla.
-----Original Message-----
From: Tech-talk [mailto:[email protected]] On Behalf Of Randall Cayford via Tech-talk
Sent: Tuesday, December 21, 2021 9:34 AM
To: Gofron, Kazimierz via Tech-talk <[email protected]>
Subject: Multiple IOCs on a remote server
I’ve run into a problem I don’t understand.  I’m running 2 IOCs on a machine in a different subnet.   I can access the PVs by adding the remote machine’s IP address to my CA_ADDRESS_LIST.  However I can only access the PVs from one of the IOCs - the IOC that I start second.  Whichever IOC I start second. PVs from both are accessible from machines on the same subnet at the same time but only one set of PVs is accessible remotely.  If I restart the first IOC then it becomes the accessible one and the other becomes inaccessible.
I’ve tried setting up a cagateway on the remote machine and the behavior is the same.   Is there some trick to running multiple IOCs on a machine without which only one will respond to remote requests?
Randall
LBNL
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
Multiple IOCs on a remote server Randall Cayford via Tech-talk
RE: Multiple IOCs on a remote server Abdalla Ahmad via Tech-talk
Prev: RE: Multiple IOCs on a remote server Abdalla Ahmad via Tech-talk
Next: Job opportunity at PSI: Section Head Control Systems Schilcher Thomas (PSI) via Tech-talk
