1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Start IOC automatically at boot
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: Ralph Lange via Tech-talk <[email protected]>
Date: Wed, 05 Jan 2022 21:30:07 +0100
Happy new year!
I am trying to install systemd-softioc (procServ) as outlines here https://github.com/NSLS-II/systemd-softioc. I followed the instructions and successfully installed it on my Raspberry Pi. I installed the IOC and can manually start the softioc, however I am not able to start the IOC using manage-iocs. I get the following output:
softioc@raspberrypi:/epics/iocs/testIOC2$ sudo manage-iocs start testIOC2
Starting the IOC 'testIOC2' ...
Failed to start the IOC 'testIOC2'; type 'sudo journalctl -xe' for details.
Below is my config file and output from the journalctl
Config
NAME=testIOC2
PORT=4053
HOST=raspberrypi
USER=softioc
CHDIR="/epics/iocs/testIOC2/iocBoot/ioctestIOC2"
EXEC="$CHDIR/st.cmd"
Output from journalctl
Jan 05 21:11:29 raspberrypi sudo[13371]: softioc : TTY=pts/0 ; PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/manage-iocs install testIOC2 Jan 05 21:11:29 raspberrypi sudo[13371]: pam_unix(sudo:session): session opened for user root by (uid=0) Jan 05 21:11:29 raspberrypi sudo[13371]: pam_unix(sudo:session): session closed for user root Jan 05 21:11:43 raspberrypi sudo[13423]: softioc : TTY=pts/0 ; PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/manage-iocs start testIOC2 Jan 05 21:11:43 raspberrypi sudo[13423]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 05 21:11:43 raspberrypi systemd[1]: Reloading.
Jan 05 21:11:43 raspberrypi systemd[1]: [email protected]: Current command vanished from the unit file, execution of the command list won't be resume Jan 05 21:11:43 raspberrypi systemd[1]: plexmediaserver.service: Current command vanished from the unit file, execution of the command list won't be resumed. Jan 05 21:11:44 raspberrypi systemd[1]: Condition check resulted in IOC testIOC2 via procServ being skipped. -- Subject: A start job for unit softioc-testIOC2.service has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit softioc-testIOC2.service has finished successfully.
-- The job identifier is 1803.
Jan 05 21:11:45 raspberrypi sudo[13423]: pam_unix(sudo:session): session closed for user root Jan 05 21:11:54 raspberrypi sudo[13487]: softioc : TTY=pts/0 ; PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/journalctl -xe Jan 05 21:11:54 raspberrypi sudo[13487]: pam_unix(sudo:session): session opened for user root by (uid=0)
The softioc testIOC2 contains a few records which get updated from a python script. Which brings me to my next questions. Is there a way to automatically start the python script with the ioc?
Thank you very much for your help,
Regards
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Re: Start IOC automatically at boot Hu, Yong via Tech-talk
RE: Start IOC automatically at boot GAGET Alexis via Tech-talk
Prev: RE: Multiple IOCs on a remote server Manoussakis, Adamandios via Tech-talk
Next: Re: ADVimba memory leak ? John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Start IOC automatically at boot Hu, Yong via Tech-talk
