1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Questions from the Static Database Access chapter of the Application Developer's Guide
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 1 Feb 2022 00:23:32 +0000
Hi Andy,
On Jan 31, 2022, at 1:53 AM, Wang, Andrew via Tech-talk <[email protected]> wrote:
I have a quick question regarding dbReadDatabase. Based upon my understanding, it seems that it is meant for loading a file containing database definitions, which I presume comes from files with a .dbd extension. However, in Chapter 14.16.1, I noticed that one of the lines of code seems to imply that we can pass .db files into the arguments of dbReadDatabase. I was wondering if that is a typo.
No, both dbReadDatabase() can be used to read either type of file, the IOC has a single parser which handles all of the syntax described in the database definition chapter 6.2.
Additionally, I am a bit curious about how to utilize some of the functions pertaining to record instances. For instance, dbGetNRecords allows us to get the number of record instances for the record type that DBENTRY references. However, I can’t locate a function that allows me to pass a filename to a record instance file with all the record instances within it.
The dbStaticLib API was designed for writing tools to manipulate databases as well as for internal use by the IOC, and it doesn’t encompass everything you need, look at the dbAccessDefs.h header for the dbLoadDatabase() and dbLoadRecords() functions (AppDev chapter 6.10) for instance. Those functions both call dbReadDatabase() to do the actual parsing.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
RE: Questions from the Static Database Access chapter of the Application Developer's Guide Wang, Andrew via Tech-talk
Prev: Re: Phoebus-olog integration Kasemir, Kay via Tech-talk
Next: EPICS Qt 3.8.1 [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Questions from the Static Database Access chapter of the Application Developer's Guide Wang, Andrew via Tech-talk
Next: RE: Questions from the Static Database Access chapter of the Application Developer's Guide Wang, Andrew via Tech-talk
