> And I always configure
the serial port settings on the terminal server and just use the drvAsynIPPortConfigure() to talk to the device
through the network.
> Much simpler that way, no need for cumbersome protocols.
The advantage of putting the serial port configuration (baud, bits, parity, etc.) in the startup script is that it will then normally be under source release control, and hence difficult
to lose. If the settings are only inside the non-volatile memory of the terminal server they are less likely to be recorded. When the terminal server fails (and they do) the settings need to be recreated.
The protocol as implemented in drvAsynIPPort is not cumbersome: the serial port configuration commands in the startup script are identical to those for local serial ports, and the
API for writing and reading data is identical, whether or not the COM modifier to drvAsynIPPortConfigure is used.
Sent: Thursday, February 3, 2022 1:15 AM
To: [email protected] <[email protected]>
Subject: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers)
Dear Jakub,
I work with Moxa terminal servers a lot. We have a lot of 1990 style serial hardware…. And I always
configure the serial port settings on the terminal server and just use the drvAsynIPPortConfigure() to
talk to the device through the network. Much simpler that way, no need for cumbersome protocols.
Best Regards,
Mark Koennecke
- Re: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Bradnick, Ben (DLSLtd, RAL, LSCI) via Tech-talk
- .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Koennecke Mark (PSI) via Tech-talk
RE: Omron Ethercat Motor Controllers Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
