1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Compilation of IOC using OPC UA device support
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 9 Feb 2022 13:58:50 +0100
Hi Gabriel,
The surprising thing I see is in your CONFIG_SITE.local:
UASDK_USE_XMLPARSER = NO
That would assume that your SDK was compiled without XML support and remove libxml from the linker line.
UA's evaluation bundle is compiled with XML support, so you should change the setting to YES.
Also, if your libxml is installed using the system package manager, the lines
XML_INCLUDE = /usr/include/libxml2
XML_DIR = /usr/lib64
are not necessary and could/should be removed.
Cheers,
~Ralph
Re: Compilation of IOC using OPC UA device support Ralph Lange via Tech-talk
Compilation of IOC using OPC UA device support DESMARCHELIER Gabriel via Tech-talk
Prev: Compilation of IOC using OPC UA device support DESMARCHELIER Gabriel via Tech-talk
Next: Re: Compilation of IOC using OPC UA device support Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
