1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Connecting Basler camera with areaDetector on Windows
From: "Sullivan,Bryan via Tech-talk" <[email protected]>
Date: Wed, 9 Feb 2022 17:15:54 +0000
I am trying to connect a Basler camera with areaDetector. I saw in a previous tech-talk (https://epics.anl.gov/tech-talk/2020/msg00388.php) that the aravisGigE and ADAravis modules should work with basler. I would prefer to use ADAravis since it is newer and better optimized, but when reading the documentation, I saw that ADAravis explicitly states that it cannot be used on windows because the underlying library aravis does not support it  (https://areadetector.github.io/master/ADAravis/ADAravis.html) but in the aravis documentation it gives instruction on how to install on windows (https://github.com/AravisProject/aravis).  Then with aravidGigE the documentation says it works on windows but then only gives instruction on how to install on lunix.
The questions I have are
  1. Can ADAravis be used on windows?
  2. Given a set of instructions for installing on lunix how can I adapt those to install on windows?
Bryan
RE: Connecting Basler camera with areaDetector on Windows Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Creating a database record Vodopivec, Klemen via Tech-talk
Next: RE: Connecting Basler camera with areaDetector on Windows Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: Compilation of IOC using OPC UA device support DESMARCHELIER Gabriel via Tech-talk
