1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Creating a database record
From: "Dudley, David via Tech-talk" <[email protected]>
Date: Tue, 15 Feb 2022 14:40:33 +0000
Would it be possible to perform this function from inside the iocInit function chain?  When iocInit(0) is performed, I install an init function hook to receive all the init steps.  Could I build and install a database during – say- the  initHookAfterInitDevSup announcement?  At that point, I push a database out to a temp file, and the load it in using a call to dbReadDatabaseFP, or similar?
This is just to make a couple of statistics records available every time the driver loads, but I could see other uses for it.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, February 04, 2022 3:48 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Creating a database record
[EXTERNAL] This email originated from outside of FRIB
On Thu, 3 Feb 2022 at 21:01, Dudley, David via Tech-talk <[email protected]> wrote:
Is it possible from with a device driver that before iocInit (or during some part of it) to programmatically build a database record for use in EPICS?
I know of a driver that does that, yes.
In the initialization of the driver (started by calls from the startup script) they detect the hardware and create a matching DB file in '/tmp', then load that file. Works fine.
I don't like that for a production system for multiple reasons. Having no or little control over which records an IOC loads.... Broken cards that would just disappear from the name space with no trace....
But I see the advantage for plug-and-play lab use.
If you don't hard code the records into the driver code, but maybe blow up from templates that are part of your application, you would give the user at least some control.
Cheers,
~Ralph
Re: Creating a database record Michael Davidsaver via Tech-talk
Creating a database record Dudley, David via Tech-talk
Re: Creating a database record Ralph Lange via Tech-talk
Prev: Re: [EXTERNAL] Pheobus Alarm-System - Handling varying locations for associated displays Kasemir, Kay via Tech-talk
Next: Re: Creating a database record Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Creating a database record Vodopivec, Klemen via Tech-talk
