1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Mailbox on MVME6100
From: Amit Chauhan via Tech-talk <[email protected]>
Date: Tue, 22 Feb 2022 19:20:00 +0530
Hello All,
Does anyone has experience of implementing mailbox shared-memory and mailbox interrupt between two MVME6100 CPUs in the same chassis running vxWorks 6.9 ?
Using the explanation given in target.ref file for mv6100, I am not getting the desired result.
Amit
Prev: Re: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Mark Rivers via Tech-talk
Next: Re: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Job opening at PSI (Group leader Control systems integration) Celcer Tine (PSI) via Tech-talk
Next: AsynInt32 SCAN=I/O Intr response Eric Norum via Tech-talk
