1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: strange error Pop up error in win10 epics
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 4 Mar 2022 11:44:57 +0100
On Fri, 4 Mar 2022 at 11:02, 网易邮件中心 via Tech-talk <[email protected]> wrote:
    I have a question about epics in Win10(64).
    I installed base 7.0.6.1 in win10 successfully. Then I created an example named example1 using makeBaseApp.pl.
    When I executed the example1.exe, I got these error(it is a pop up error): ( i try to use the cmd command D:\windowsEpics\firstExample\bin\windows-x64-mingw\example1.exe st.cmd  and try to double click example1.exe ,same error came out )
Hello Lynn,
Assuming you followed the Windows instructions at
Which choices for environment, compilation, linking, and deployment did you make?
Cheers,
~Ralph
strange error Pop up error in win10 epics 网易邮件中心 via Tech-talk
Prev: strange error Pop up error in win10 epics 网易邮件中心 via Tech-talk
Next: Develop motor drivers using controller's DLL 岳宗仰 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
