1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Stream device IOC does not exit under procServ
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>
Date: Wed, 9 Mar 2022 07:54:24 -0800
On 3/9/22 02:00, Abdalla Ahmad via Tech-talk wrote:
Hi
We have an IOC to control two types of devices using stream device, a high-voltage PS from matsusada and a current pre-amplifier from SRS. The problem is that when typing exit on the IOC shell the IOC does not exit, so I tried excluding devices from the IOC and it seems the problem is with the HVPS, when excluded from the IOC it exits normally and restarts under procServ. I enabled asyn masks using asynTraceMask and asyntraceIOMask, even after the exit the IOC is doing IO with the device with no problem. I was using asyn 4.30 and stream 2.8.16 I think so I pulled the latest version of all drivers and still the same behavior.
Maybe an issue with an epicsAtExit() hook?
You could try setting 'atExitDebug' prior to 'exit' to print
a message as each hook function is called.
var atExitDebug 1
Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
Prev: Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
Next: Re: Stream device IOC does not exit under procServ Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
