1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Andor3 issue connecting camera
From: Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 15 Mar 2022 10:52:33 +0000
Hi All
Found out where I was going wrong. Just have to make WITH_GRAPHICSMAGICK = NO in configure/CONFIG_SITE.local. Graphicmagic.dll generated from ADSupport conflicts with that from Andor SDK.
Thanks
Sandeep
From: Tech-talk <[email protected]> on behalf of Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
Sent: 09 March 2022 12:40
Subject: Andor3 issue connecting camera
Hi All
Andor3 driver is not able to detect the camera on Windows. I am using IOC bundled with the ADAndor3 driver. Camera is streaming in Andor SOLIS. Ironically, when I run listdevices.exe (created on ADAndor3 build). I get what I am supposed to get
Found 1 Devices.
Device 0 : NEO-5.5-CL3
In andor3 constructor, AT_InitialiseLibrary returns success. I have added AT_GetInt(AT_HANDLE_SYSTEM, L"Device Count", &DeviceCount) for debugging before connectCamera() . Looks like it has not detected the device itself (Device ID is 0)
Found 0 Devices.
2022/03/09 06:41:00.641 andor3:connectCamera: unable to open camera 0
2022/03/09 06:41:00.641 andor3:andor3:  camera connection failed (6)
Below are the EPICS versions I am using
Base - 7.0.3
Asyn - R4-43
ADCore - R-3-12-1
ADAndor3 - master(0cfa8b6) [I also tried SDK3.15 branch]
FYI, I have added Andor SDK3 (from manufacturer) dlls in the environment path.  The observation is camera works with standalone executable (listdevices/binTest/rateTest) but not with ADAndor3 IOC. Any Idea where I am going wrong?
Many Thanks
Sandeep Malu
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Andor3 issue connecting camera Sandeep Kumar Malu - STFC UKRI via Tech-talk
Prev: ORCA Flash4.0 integration Tomasz Brys via Tech-talk
Next: RE: Linking PVs to EGU field Liu, Wanming via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Andor3 issue connecting camera Sandeep Kumar Malu - STFC UKRI via Tech-talk
Next: Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
