1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: EPICS areaDetector plugin & phoebus
To: "Kasemir, Kay" <[email protected]>
Date: Mon, 11 Apr 2022 16:12:54 +0000
Ø  As far as I know, implementations of compression/decompression like the one for ImageJ call out to native libraries
That is true.  But the decompression libraries are all built in ADSupport in a way that makes them easy to call from other applications and languages, including Java.  They are called from ImageJ, and also from the HDF5 library via its run-time plugin mechanism.  This means that HDF5 applications do not need to be linked with the decompressors, they can find and load them at run-time.
Because they are built from source in ADSupport, there are minimal dependencies on OS packages.
From: Tech-talk <[email protected]> On Behalf Of Kasemir, Kay via Tech-talk
Sent: Monday, April 11, 2022 10:30 AM
To: '[email protected]' <[email protected]>
Subject: Re: EPICS areaDetector plugin & phoebus
> I’ve forgotten if CSS/Phoebus supports compressed PVA NTNDArray objects, but that would help a lot when visualizing large arrays.
It doesn't. As far as I know, implementations of compression/decompression like the one for ImageJ call out to native libraries, see decompress*.. code in https://github.com/areaDetector/ADViewers/tree/78cb7127d655685d9f4f2c83f0d83c7e5b758d58/ImageJ/EPICS_areaDetector. If we supported that in Phoebus, we could no longer offer a generic Windows/Linux/Mac version, everybody would have to locally compile the compression code.
EPICS areaDetector plugin & phoebus Jörn Dreyer via Tech-talk
Re: EPICS areaDetector plugin & phoebus Mark Rivers via Tech-talk
RE: EPICS areaDetector plugin & phoebus Pearson, Matthew via Tech-talk
Re: EPICS areaDetector plugin & phoebus Kasemir, Kay via Tech-talk
Prev: Re: EPICS areaDetector plugin & phoebus Kasemir, Kay via Tech-talk
Next: Synchronizing external changes to target instrument with EPICS Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: ADAravis PoolUsedBuffers Steve Kinder - STFC UKRI via Tech-talk
