1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Dynamically changing HIHI PV field
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Tue, 12 Apr 2022 13:39:03 +0000
Hello all.
I have an equipment which has the HIGH field configurable in the hardware. We already have a PV that reads it, but it is currently an entire PV, and not a field of another existing PV.
Im trying to get that PV result and put it in the HIGH field of another PV. Something like:
record(ai, "MY:PV") {
  field(HIHI, 10)
  field(HIGH, "ANOTHER:PV:HIGH:LIMIT PP")
  field(LOW, -1)
  field(LOLO, -5)
  field(HHSV, MAJOR)
  field(HSV, MINOR)
  field(LSV, MINOR)
  field(LLSV, MAJOR)
but each try of mine gets either syntax error or 'Can't set "MY:PV.HIGH" to "ANOTHER:PV:HIGH:LIMIT"'. Am i doing something wrong? Is this approach even possible?
Thanks in advance for any help.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Dynamically changing HIHI PV field Torsten Bögershausen via Tech-talk
Re: Dynamically changing HIHI PV field Andrew Johnson via Tech-talk
Prev: Re: Process linux system file values as PVs Han Lee via Tech-talk
Next: Re: Dynamically changing HIHI PV field Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
