1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: caQtDM caCamera widget not rendering images
From: Ashish Sharma via Tech-talk <[email protected]>
Date: Wed, 13 Apr 2022 22:35:03 +0530 (IST)
Hello Mark,
I was out of office for last few days. I just now tried with settings you told. I am now facing issues even with imagej may be because of link speed and memory issues. Here is what is returned from EPICS server:
when the server and caQtDm are running:
printenv EPICS_CA_MAX_ARRAY_BYTES
5000000000
caget 13ARV1:image1:ArrayData
CA.Client.Exception...............................................
    Warning: "The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES"
    Context: "op=0, channel=13ARV1:image1:ArrayData, type=DBR_TIME_SHORT, count=4665600, ctx="server unable to load read (or subscription update) response into protocol buffer PV="13ARV1:image1:ArrayData" max bytes=2147483671""
    Source File: ../getCopy.cpp line 92
    Current Time: Wed Apr 13 2022 11:58:23.810332518
EPICS_CA_MAX_ARRAY_BYTES is greater but how to correct available memory?
This PV is responsible for data display on caCamera widget and even on ImageJ. What could be done to correct this? Image size is 388800 bytes (720 x 540 x 1 for mono) which I think is less than the memory available.
Earlier ImageJ was working, now it is saying that "Unable to Connect EPICS PV" and "CACONNECTION Exception" and 13ARV1:image1: is red in color with blank NX, NY, NZ fields.
Client CLI is throwing error:
CAC: not enough memory for message body cache (ignoring response message)
Could you please help in setting things right?
Thank you in anticipation.
Ashish
To: "Ashish Sharma" <[email protected]>
Cc: "tech-talk" <[email protected]>
Sent: Friday, April 1, 2022 6:03:14 PM
> Could you please elaborate "Are you sure it is also set OK on the caQtDM process?" As to what variable to look for in this?
Just before you launch caQtDM, either manually or in a script, execute this command:
printenv EPIC_CA_MAX_ARRAY_BYTES
> Moreover, a detailed guide for installation and make it working using ADAravis and ADGenICam would be really helpful. Could you please provide a link?
The areaDetector documentation home page is here:
The installation Guide is here:
ADAravis documentation is here:
ADGenICam documentation is here:
> ​Another thing, is it advisable to install MEDM on Ubuntu 20.04 as lots of x11 packages have gotten obsolete for this version. We are working on EPICS7.
I have not used Ubuntu 20, but I have built medm on Ubuntu 18. areaDetector comes with screens for medm, edm, caQtDM, CSS/Boy and CSS/Phoebus.  Most of these are autoconverted from medm screens.
Sent: Friday, April 1, 2022 6:47 AM
Thanks Mark for quick response.
Thanks again
Ashish
To: "Ashish Sharma" <[email protected]>, "tech-talk" <[email protected]>
Sent: Thursday, March 31, 2022 6:12:48 PM
Hi Asjish,
Since ImageJ works it looks like EPICS_CA_MAX_ARRAY_BYTES must be set OK on the IOC and on the ImageJ process.  Are you sure it is also set OK on the caQtDM process?
It is not related to this problem, but I would suggest you consider migrating from aravisGigE to ADAravis (or ADSpinnaker). arabisGigE is no longer actively supported.
Sent: Thursday, March 31, 2022 1:09 AM
To: tech-talk <[email protected]>; Mark Rivers <[email protected]>
Subject: caQtDM caCamera widget not rendering images
Hello,
I am trying to add a new camera (FLIR's Blackfly S) into areaDetector (aravisGigE) with GUI on caQtDM. Earlier I had the attached GUI completely working with both ImageJ and caCamera widget able to render the images. But now after changes in my camera processor board (new serial ID etc.), all things except for caCamera are working. X-Y profiles are working but caCamera is unable to render any image.
I have made no changes in the settings just replaced the earlier .edl and -feature.edl files (and also the .ui files) with new ones based on the xml config file of new camera.
Could you please help me here. I doubt on the caQtDm installation. Or anything else?
Thank you.
Ashish Sharma
Engineer 'D'
Inter-University Accelerator Centre,
Aruna Asaf Ali Marg, New Delhi - 110067
Mob. : +91-7982808263, +91-9868528158
Off. : 011-24126024 (Ext : 229 / 8804)
RE: caQtDM caCamera widget not rendering images Mark Rivers via Tech-talk
caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
Re: caQtDM caCamera widget not rendering images Mark Rivers via Tech-talk
Re: caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
Prev: Phoebus - xygraph print question Amien Crombie via Tech-talk
Next: EPICS Tools and Services codeathon track Shroff, Kunal via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: caQtDM caCamera widget not rendering images Mark Rivers via Tech-talk
Next: RE: caQtDM caCamera widget not rendering images Mark Rivers via Tech-talk
