1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Can't edit opi in CSS
To: Rebecca Harding - STFC UKRI <[email protected]>
Cc: [email protected]
Date: Thu, 21 Apr 2022 12:34:04 +0200
Hello Rebecca,
probably in your CSS, you have "No-Editing mode" enabled. It is possible to disable this option under
Preferences -> CSS Applications -> Display -> BOY
...and remember to restart the application in order to reload the new setup.
Just a note: version 3.2.16 is a really old version of CSS, you should consider moving to a newer version for better support.
Best Regards
Maurizio
Il 2022-04-21 12:04 Rebecca Harding - STFC UKRI via Tech-talk ha scritto:
Hello TechTalk,
I’m having a problem with Control System Studio.
I want to open an opi in edit mode but for some reason it’s sometimes just not possible.
I open the navigator, right click on the opi, and select Open With OPI Editor. After I’ve clicked it, the opi appears in edit mode for a fraction of a second, but then it just runs (i.e. is in OPI Runtime mode). I don’t understand why this happens and I can’t seem to find any way at all to edit my opi.
I have ensured no other screens are open. I have tried restarting CSS a few times (Restart CSS button and killing it with Task Manager) but it makes no difference. I’m using CSS version 3.2.16.20140409 running on a Windows 10 machine.
Please let me know if you have any suggestions.
Kind regards,
Rebecca Harding
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
~~ Maurizio Montis - Control System Engineer ~~
   office: +39 0498068558
   mobile: +39 3408428089
   mail: [email protected]
   skype: maurizio_montis
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
   V.le dell'Universita', 2
   35020 LEGNARO (PD) - ITALY
Can't edit opi in CSS Rebecca Harding - STFC UKRI via Tech-talk
Prev: Can't edit opi in CSS Rebecca Harding - STFC UKRI via Tech-talk
Next: Getting Permission denied messages while building Barrett (US), Patrick E via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
