Subject: |
Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address |
Michael Davidsaver via Tech-talk <[email protected]> |
To: |
Heinz Junkes <[email protected]> |
Cc: |
EPICS Tech Talk <[email protected]> |
Date: |
Fri, 22 Apr 2022 12:41:17 -0700 |
On 4/22/22 11:51, Heinz Junkes via Tech-talk wrote:
we need to route the announcements from our central Channelfinder server to a subnet so that the
recasters on the IOCs in the subnet can send their PV information to the server.
Unfortunately, the announcement package does not contain the IP of the server but FF:FF:FF:FF.
How are you planning to "route"?
Playing games with routing rules, or mangling via. something like iptables/netfilter won't change
the IP source address, which is what SERV ADDR == 0xffffffff means (as with CA or PVA).
If you are thinking to create an active repeater (application level proxy), then this app. will
need to copy the original IP source address into SERV ADDR field.
https://github.com/ChannelFinder/recsync#udp-protocol
root@priscilla:~# socat -ls -u -v -x UDP4-RECVFROM:5049,broadcast,fork,bind=141.14.143.255 UDP4-SENDTO:10.0.1.255:5049,broadcast
2022/04/22 17:22:18.879313 length=16 from=0 to=15
52 43 00 00 ff ff ff ff 84 81 00 00 61 bf c1 23 RC..........a..#
Gruss Heinz
- Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Heinz Junkes via Tech-talk
- Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Heinz Junkes via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
