1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: Showing specific elements from an array record on CS Studio
To: "Wang, Andrew" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 26 Apr 2022 07:00:00 +0000
Hi Andy,
You could use the filter that selects specific sub-arrays: <pv_name>.[array_item]
More info is available here:
https://epics.anl.gov/base/R3-15/6-docs/filters.html#Array-Filter-arr
Best regards,
Žiga
From: Tech-talk <[email protected]> On Behalf Of Wang, Andrew via Tech-talk
Sent: torek, 26. april 2022 03:47
To: EPICS tech-talk <[email protected]>
Subject: Showing specific elements from an array record on CS Studio
Hi all,
I was wondering what is the preferred method of displaying certain elements of an array record in a text box on CS Studio.
Suppose I have these five text boxes and I have an array record called “rec_1”.
How can I have the first text box show the first element of “rec_1”, the second text box shows the second element, etc.
Thank you,
Andy
Purple ribbon awareness
Showing specific elements from an array record on CS Studio Wang, Andrew via Tech-talk
Prev: Showing specific elements from an array record on CS Studio Wang, Andrew via Tech-talk
Next: Re: pyDevSup and PyDevice: Virtual Environment Kuldeep Joshi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: areaDetector ImageJ EPICS_AD_VIEWER Petra Schwalbach via Tech-talk
