1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: NDArrayPool:reserve ERROR, reference count = 0, should be = 1
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Daykin, Evan" <[email protected]>
Date: Tue, 3 May 2022 09:10:04 -0700
On 5/3/22 08:52, Daykin, Evan via Tech-talk wrote:
Hm… I am not explicitly calling release() anywhere. This is my processCallbacks function-  everything else in my plugin, AFAIK, doesn’t access any shared resources.
I have half a memory that NDPluginDriver::endProcessCallbacks() "steals"* a reference
to the NDArray when copyArray=false.
* https://docs.python.org/3/c-api/intro.html#reference-count-details
void NDPluginTemperature::processCallbacks(NDArray *pArray){
     static const char *functionName = "processCallbacks";
     NDArrayInfo_t arrayInfo;
     if(pArray->dataType != NDUInt16){
         asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
         "%s:%s: Only UInt16 supported.", driverName, functionName);
         return;
     std::string lastCalFileName = this->calibrationFileName;
     getStringParam(this->calibrationFileNameIdx, this->calibrationFileName);
     if(this->calibrationFileName != lastCalFileName){
         this->processCalibrationFile();
     int arrayCallbacks;
     getIntegerParam(NDArrayCallbacks, &arrayCallbacks);
     if(arrayCallbacks==1){
         epicsTimeStamp before;
         epicsTimeGetCurrent(&before);
         NDPluginDriver::beginProcessCallbacks(pArray);
         this->pNDArrayPool->convert(pArray,&(this->inputArray), NDUInt16);
         if(NULL == this->outputArray){
             this->pNDArrayPool->convert(pArray,&(this->outputArray),NDUInt16);
         //unlock while the plug-and-chug happens. No shared resources are accessed at this time.
         inputArray->getInfo(&arrayInfo);
         this->unlock();
         this->doTemperatureConversion(this->inputArray, this->outputArray, &arrayInfo);
         this->lock();
         setIntegerParam(NDArraySizeX, (int)outputArray->dims[arrayInfo.xDim].size);
         setIntegerParam(NDArraySizeY, (int)outputArray->dims[arrayInfo.yDim].size);
        epicsTimeStamp after;
         epicsTimeGetCurrent(&after);
         double delta = epicsTimeDiffInSeconds(&after, &before);
         cout<<"Took "<<delta<<" s"<<endl;
         setDoubleParam(runTimeIdx, delta);
         NDPluginDriver::endProcessCallbacks(outputArray, false, true);
         callParamCallbacks();
*Sent:* Tuesday, May 3, 2022 11:37 AM
*To:* [email protected]; Daykin, Evan <[email protected]>
*Subject:* Re: NDArrayPool:reserve ERROR, reference count = 0, should be = 1
*[EXTERNAL] This email originated from outside of FRIB*
Hi Evan,
That error probably means you have called NDArray::release() on an array whose reference count is already 0.
Most plugins don't need to call release() because it is handled in the base class NDPluginDriver::endProcessCallbacks().
*From:*Tech-talk <[email protected] <mailto:[email protected]>> on behalf of Daykin, Evan via Tech-talk <[email protected] <mailto:[email protected]>>
*Sent:* Tuesday, May 3, 2022 10:20 AM
*To:* [email protected] <mailto:[email protected]> <[email protected] <mailto:[email protected]>>
*Subject:* NDArrayPool:reserve ERROR, reference count = 0, should be = 1
I am hoping there’s an AreaDetector plugin maven here…
I have written a small AD plugin intended to convert our raw camera images into a temperature heatmap, based on a calibrated gain, emissivity and exposure time. To test it, I set up a SimDetector in “peak” mode. I connect my plugin to this simDetector image. I can successfully capture and convert 3 frames. On the fourth frame, my test dies with the following error. Are there any common pitfalls that might cause this?
NDArray.uniqueId=1
Do temperature conversion start
Took 0.0937809 s
NDArray.uniqueId=2
Took 0.0655851 s
NDArray.uniqueId=3
Took 0.0642867 s
NDArray.uniqueId=4
NDArrayPool:reserve ERROR, reference count = 0, should be >= 1, pArray=0x7f453c001d80
Thread SimDetTask (0x5621bbbb0c80) can't proceed, suspending.
Dumping a stack trace of thread 'SimDetTask':
[    0x7f45538ffab3]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(epicsStackTrace+0x73)
[    0x7f45538f0216]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(cantProceed+0xc6)
[    0x7f4553197b08]: /lib/x86_64-linux-gnu/libADBase.so.3.11(_ZN11NDArrayPool7reserveEP7NDArray+0x78)
[    0x7f455305db37]: /lib/x86_64-linux-gnu/libNDPlugin.so.3.11(_ZN14NDPluginDriver21beginProcessCallbacksEP7NDArray+0x367)
[    0x7f455375df1e]: /home/daykin/git/areadetector-temperature/lib/linux-x86_64/libNDPluginTemperature.so(_ZN19NDPluginTemperature16processCallbacksEP7NDArray+0xae)
[    0x7f455305dd53]: /lib/x86_64-linux-gnu/libNDPlugin.so.3.11(_ZN14NDPluginDriver14driverCallbackEP8asynUserPv+0x1d3)
[    0x7f4553851155]: /lib/x86_64-linux-gnu/libasyn.so.4.38(_ZN14asynPortDriver25doCallbacksGenericPointerEPvii+0x1f5)
[    0x7f4553809974]: /usr/lib/epics/lib/linux-x86_64/libsimDetector.so(_ZN11simDetector7simTaskEv+0x4e4)
[    0x7f45538fa0bb]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(epicsSnprintf+0x7bb)
[    0x7f4553387ea7]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xd7)
[    0x7f455349edef]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
*Evan Daykin*
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email: [email protected] <mailto:[email protected]>
*cid:[email protected]*
RE: NDArrayPool:reserve ERROR, reference count = 0, should be = 1 Daykin, Evan via Tech-talk
Re: NDArrayPool:reserve ERROR, reference count = 0, should be = 1 Mark Rivers via Tech-talk
Prev: RE: NDArrayPool:reserve ERROR, reference count = 0, should be = 1 Daykin, Evan via Tech-talk
Next: RE: NDArrayPool:reserve ERROR, reference count = 0, should be = 1 Daykin, Evan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
