Hi Dirk,
Thanks for the suggestion. The StreamDevice was installed from a prebuilt package and it seems to have PCRE linked:
liji@xf04bm-maia:/epics/iocs/maia$ ldd bin/linux-x86_64/maia |grep stream
libstream.so => /usr/lib/epics/lib/linux-x86_64/libstream.so (0x00007f0139e55000)
liji@xf04bm-maia:/epics/iocs/maia$ ldd /usr/lib/epics/lib/linux-x86_64/libstream.so |grep pcre
libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007fecb0427000)
Something must have broken. I compiled a seperate StreamDevice instance and rebuilt the IOC. Errors are gone. We will double check the StreamDevice package. Thanks.
Hi Ji
It looks like PCRE (perl regular expressions) is not linked into StreamDevice.
Check your PCRE settings in RELEASE.
Be aware that from StreamDevice 2.7 to 2.8 I made some modifications to the Makefiles when searching for the configure directory to be more "standard EPICS compatible". In particular I look into the local configure
first instead of an upper level configure. So maybe you need to copy some settings over?
Dirk
Von: Tech-talk <[email protected]>
Im Auftrag von Li, Ji via Tech-talk
Gesendet: Donnerstag, 12. Mai 2022 23:47
An: [email protected]
Betreff: Regex support in StreamDevice.
We have an IOC based on streamdevice which had been work well until it was recently updated to base 7.0.5 and StreamDevice 2.8.10. The IOC reported erros on startup:
2022/05/12 17:20:06.024569 _main_ No converter registered for format '%/'
2022/05/12 17:20:06.024610 _main_ var.p line 398: in format string: "%/^(?|\"([^\"]*)\"|([^\"][^ ]*))/"
2022/05/12 17:20:06.024616 _main_ var.p line 398: in command 'in'
2022/05/12 17:20:06.024620 _main_ var.p line 395: in protocol 'var_g_string'
2022/05/12 17:20:06.024627 _main_ while compiling protocol 'var_g_string(position.dim[0].name,XFM:MAIA)' for 'XFM:MAIA:X_POS_DIM_NAME'
2022/05/12 17:20:06.024633 _main_ XFM:MAIA:X_POS_DIM_NAME: Protocol parse error
2022/05/12 17:20:06.024639 _main_ XFM:MAIA:X_POS_DIM_NAME: Record initialization failed
It seems "%/^(?|\"([^\"]*)\"|([^\"][^ ]*))/" in protocol var_g_string could not be recognized as a regular _expression_.
The StreamDevice was built against PCRE package, and:
liji@xf04bm-maia:/epics/iocs/maia$ ldd bin/linux-x86_64/maia | grep pcre
libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007fcd23fdb000)
What could be preventing streamdevice from parsing protocols with regular expressions?
- AW: Regex support in StreamDevice. Zimoch Dirk (PSI) via Tech-talk
- Regex support in StreamDevice. Li, Ji via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
