1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Octal escape sequence translation issue in base 7.0.6.1?
Date: Tue, 17 May 2022 21:17:54 +0000
Folks,
I just switched to using base 7.0.6.1 on my beamlines.  When I try to start a Pilatus detector I get this error:
# Set the input and output terminators.
asynOctetSetInputEos("camserver", 0, "\030")
Set EOS failed: camserver illegal eoslen 3
It appears that it is interpreting the escape sequence \030 as a string of 3 characters rather than as a single character.  Is this a bug in base 7.0.6.1 or a problem with my syntax?  This used to work fine with base 7.0.4, I have not changed anything.
Re: Octal escape sequence translation issue in base 7.0.6.1? Andrew Johnson via Tech-talk
Prev: compilation error with redis Pierrick M Hanlet via Tech-talk
Next: Re: Octal escape sequence translation issue in base 7.0.6.1? Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
