I assume you did look at the man page... *unix:</path/to/socket>*::
Bind to a named unix domain socket that will be created at the specified
absolute or relative path. The server process must have permission to
create files in the enclosing directory.
The socket file will be owned by the uid and primary gid of the procServ
server process with permissions 0666 (equivalent to a TCP socket bound to
localhost).
*unix:<user>:<group>:<perm>:</path/to/socket>*::
The socket file will be owned by the specified _<user>_ and _<group>_
with _<perm>_ permissions.
Any of _<user>_, _<group>_, and/or _<perm>_ may be omitted.
E.g. "-P unix::grp:0660:/run/procServ/foo/control" will create the named
socket with 0660 permissions and allow the "grp" group connect to it.
This requires that procServ be run as root or a member of "grp".
*unix:@</path/to/socket>*::
Bind to an abstract unix domain socket (Linux specific).
Abstract sockets do not exist on the filesystem, and have no permissions
checks.
They are functionally similar to a TCP socket bound to localhost,
but identified with a name string instead of a port number.
What additional information do you need? Cheers, ~Ralph On Sat, 21 May 2022 at 00:44, Han Lee via Tech-talk <[email protected]> wrote:
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
