1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Re: issue with procserv
From: Han Lee via Tech-talk <tech-talk at aps.anl.gov>
To: Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>
Cc: tech-talk at aps.anl.gov
Date: Mon, 23 May 2022 09:51:55 -0700
Hi Florian,
On Mon, May 23, 2022 at 9:36 AM Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov> wrote:
the service file was generated by the "manage-procs add" command from the systemd-utils provided in the procserv sources.
Please check the following wiki; you can see the exact command which Andrew suggested.
An user systemd works in a slightly different way than system systemd. The configuration of the user systemd needs more effort than system systemd one. If you don't have any specific reason to keep it in an IOC user, I recommend moving that to the system systemd folder.
If you only use the manage-procs to enable this systemd unit, one might look at the mange-procs to check whether the utils contain what Andrew suggested.
Best,
Han
I also tried to enable linger as Andrew suggested, but I'm not sure the shutdown of the IOC was always related to closing the ssh connection to the raspi.
I'll keep an eye on it.
Here is the service file:
pi@scatterchamber:~ $ cat .config/systemd/user/multi-user.target.wants/procserv-epicsioc.service
[Unit]
Description=procServ for epicsioc
After=network.target remote-fs.target
ConditionPathIsDirectory=/home/pi
[Service]
Type=simple
ExecStart=/usr/local/bin/procServ-launcher --user epicsioc
RuntimeDirectory=procserv-epicsioc
StandardOutput=syslog
StandardError=inherit
SyslogIdentifier=procserv-epicsioc
[Install]
WantedBy=multi-user.target
Cheers,
Florian
Am 23.05.2022 um 16:57 schrieb montis:
Hi Florian,
could you be so kind to add the systemd service file you are using for this application? It would be useful.
You can find it under /etc/systemd/sytem or /etc/procServ.d
Thanks in advance!
Maurizio
Il 2022-05-23 10:59 Florian Feldbauer via Tech-talk ha scritto:
Hi Ralph,
I actually feared, that is has nothing to do with procserv or the ioc itself.
Unfortunately I'm not an expert for systemd myself, but I hope someone in this forum has some ideas....
Cheers,
Florian
On 5/23/22 10:54, Ralph Lange via Tech-talk wrote:
Hi Florian,
Doesn't the third line of your log
On Mon, 23 May 2022 at 10:32, Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hey all,
I currently have a problem with procserv.
I'm using the latest commit from github compilied on Raspbian OS bullseye.
I used manage-procs to create a service but the service gets stopped
every now and then.
The actual runtime seems to be quite arbitrary. Sometimes a few secs
sometimes several hours.
The log output does not really contain any helpfull information.
Any idea what could causing procserv to shut down?
CPU and RAM usage are way below 10% when the IOC is running.
Cheers,
Florian
pi@scatterchamber:~ $ systemctl --user status procserv-epicsioc.service
● procserv-epicsioc.service - procServ for epicsioc
      Loaded: loaded
(/home/pi/.config/procServ.d/procserv-epicsioc.service; enabled; vendor
preset: enabled)
      Active: inactive (dead)
May 23 10:10:17 scatterchamber procserv-epicsioc[58686]: 2022/05/23
10:10:17.505 drvModbusAsyn::doModbusIO port chillerReadReg error calling
writeRead, error=PilotONE-187144:502 TCP timeout>
May 23 10:10:18 scatterchamber procserv-epicsioc[58686]: 2022/05/23
10:10:18.604 drvModbusAsyn::doModbusIO port chillerReadReg writeRead
status back to normal having had 1 errors, nwrite=6/>
i.e., the next one
May 23 10:10:45 scatterchamber systemd[58650]: Stopping procServ for
epicsioc...
May 23 10:10:45 scatterchamber procserv-epicsioc[58686]: @@@ Current
time: Mon May 23 10:10:45 2022
May 23 10:10:45 scatterchamber procserv-epicsioc[58686]: @@@ Child
process is shutting down, a new one will be restarted shortly
May 23 10:10:45 scatterchamber procserv-epicsioc[58686]: @@@ ^R or ^X
restarts the child, ^Q quits the server, ^D closes this connection
procserv-epicsioc.service: Succeeded.
May 23 10:10:45 scatterchamber systemd[58650]: Stopped procServ for
epicsioc.
procserv-epicsioc.service: Consumed 1.799s CPU time.
suggest that systemd is deliberately shutting down the IOC?
The following log lines definitely look like procServ was told to shut down the child process.
I'm not a systemd expert enough to know what could cause that (wrong dependencies between services maybe?), but this doesn't really look like something originating within procServ or the child process.
Cheers,
~Ralph
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
~~ Maurizio Montis - Control System Engineer ~~
   office: +39 0498068558
   mobile: +39 3408428089
   mail: maurizio.montis at lnl.infn.it
   skype: maurizio_montis
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
   V.le dell'Universita', 2
   35020 LEGNARO (PD) - ITALY
NB 2/131 / Fach 125
D-44801 Bochum
Office: NB 2/134
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
issue with procserv Florian Feldbauer via Tech-talk
Re: issue with procserv Ralph Lange via Tech-talk
Re: issue with procserv Florian Feldbauer via Tech-talk
Re: issue with procserv montis via Tech-talk
Prev: Re: issue with procserv Florian Feldbauer via Tech-talk
Next: Re: issue with procserv Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
