Simply read "#800001000" before your format. For example, it your format is %r, do: in ""#800001000%r".
The waveform will repeat the format for each element, but read the header only once.
If you have changing numbers of elements, you could use "#8%*8d" to skip 8 decimals after the #8. You cannot skip a
variable number of digits though. (but that is normally not needed).
Dirk
On Wed, 2022-05-25 at 12:02 +0000, MuYuan Wang via Tech-talk wrote:
> Hello Everyone:
> When I try to write the protocol file to get waveform data from Keysight DSOX1204A oscilloscope, I
> found the waveform data format is such like “<header><data><NL>” and the header is standard format like that
> #800001000, data followed by it after, so is it some good solution can skip over the header and directly to read
> waveform data? I check the stream device documents which says using “*” but I try some methods it looks like doesn’t
> work.
> Thanks for your time and kind help.
> Best Regards
> MuYuan
- StreamDevice protocol file to skip over the header string when get waveform MuYuan Wang via Tech-talk
Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
<2022>
2025
2026
Scientific Software Positions at the Advanced Photon Source (APS) Schwarz, Nicholas via Tech-talk
<2022>
2025
2026
