1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: dbLoadRecords and substitute
To: "Knap, Giles (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Wed, 8 Jun 2022 12:32:38 +0000
Hi Giles,
I recently converted a Diamond-style database (for the Symetrie hexapod) to load at runtime and ran into that 'substitute' issue. The solution is to use dbLoadTemplate which supports substitutions.
The original version with the 'substitute' keyword is here:
The new version uses that file modified to remove the 'substitute'
plus this .substitutions file
On Jun 8, 2022, at 3:24 AM, Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]> wrote:
Hello,
I'm looking at updating our IOC build workflow (using containers) and would like to adopt the APS approach of doing database macro substitution at runtime in the IOC startup script. e.g.
    dbLoadRecords("pmacStatus.template", "PORT=BRICK1, P=BL45P-MO-STEP-01")
However I have discovered that a number of our database templates use the 'substitute' keyword. This is not supported by dbLoadRecords.
In our existing workflow we expand templates with make at IOC build time, this uses MSI which does support 'substitute'.
Can anyone suggest a workaround for this?
Is this mismatch between MSI and base intentional?
giles
Re: dbLoadRecords and substitute Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address William Kirstaedter via Tech-talk
Next: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: dbLoadRecords and substitute Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: dbLoadRecords and substitute Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
