1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Removing battery/crystal from MVME 5100
From: "Walsh, Thomas R. via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: "eric.d.stone at lmco.com" <eric.d.stone at lmco.com>
Date: Thu, 9 Jun 2022 15:12:12 +0000
Hi Eric,
I have nothing in writing, but I can tell you how I change the crystals out. I put the card on an ESD mat and then using a scribe(or small standard jeweler screwdriver) I begin lifting the corner marked with the dot . Once I feel it move a little I go to the diagonal corner and lift up. Once this corner starts to come up, the crystal is loose enough to remove with my fingers. Go slow and watch not to scratch the conformal coating of the PCB.
Tom Walsh
630-252-5621
RE: Removing battery/crystal from MVME 5100 Stone, Eric D via Tech-talk
Re: Removing battery/crystal from MVME 5100 Maren Purves via Tech-talk
Prev: RE: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
Next: PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Next: RE: Removing battery/crystal from MVME 5100 Stone, Eric D via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
