1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: StreamDevice with a REST API
From: Chris Gregory - STFC UKRI via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>, "Zimoch Dirk (PSI)" <[email protected]>
Date: Fri, 10 Jun 2022 13:34:01 +0000
Thanks both,
Just tested and I confirm that outTerminator = CR LF CR LF works for me.
Regards
Chris
Sent: 10 June 2022 14:32
To: Gregory, Chris (STFC,RAL,CLF) <[email protected]>; [email protected]; Zimoch Dirk (PSI) <[email protected]>
Subject: Re: StreamDevice with a REST API
> As the host is running on Windows, do you need CR LF CR LF? (I hope not.)
CR = <US-ASCII CR, carriage return (13)>
LF = <US-ASCII LF, linefeed (10)>
HTTP/1.1 defines the sequence CR LF as the end-of-line marker for all protocol elements except the entity-body
And you need two of them at the end of GET:
  1. Ends the GET
  2. Tells the server that there are no more request headers
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: StreamDevice with a REST API Zimoch Dirk (PSI) via Tech-talk
StreamDevice with a REST API Chris Gregory - STFC UKRI via Tech-talk
Re: StreamDevice with a REST API Kasemir, Kay via Tech-talk
Prev: Re: StreamDevice with a REST API Kasemir, Kay via Tech-talk
Next: Re: StreamDevice with a REST API Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
