Hi John,
I believe you’re going to need a later version of Asyn.
The release notes say that 64-bit integer support was added with R4-37.
Cheers,
Peter.
I just cloned areaDetector, ADCore, ADSupport, ADEiger.
Using base 7.0.3 , asyn-R4-36 I get the following error:
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DBUILDING_ADCore_API -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc
-I../../../include/os/Linux -I../../../include -I/homes/det/epics/synApps_6_1/support/asyn-R4-36/include -I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADSupport/include/os/Linux -I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADSupport/include
-I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADCore/include -I/homes/det/epics/base-7.0.3/include/compiler/gcc -I/homes/det/epics/base-7.0.3/include/os/Linux -I/homes/det/epics/base-7.0.3/include -c ../paramAttribute.cpp
../paramAttribute.cpp: In member function 'virtual int paramAttribute::updateValue()':
../paramAttribute.cpp:138:37: error: 'class asynNDArrayDriver' has no member named 'getInteger64Param'
status = this->pDriver->getInteger64Param(this->paramAddr, this->paramId,
Research Support Specialist
Cornell High Energy Synchrotron Source
- ADCore build error John Dobbins via Tech-talk
RE: ADCore build error Mark Rivers via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
