Then restart the dhcp server.
-----Original Messages-----
Sent Time:2022-06-27 18:08:50 (Monday)
To: "[email protected]" <[email protected]>
Cc:
Subject: EPICS IOC BOOTP timeout at RTEMS on MVME6100
Hello All,
I tried to run RTEMS5 + EPICS7 at mvme6100, and I followed the steps in https://epics.mpg.de/index.php?n=Software.EPICSRTEMS?userlang=en to build RTEMS5 for MVME6100.
The configure:
../../rtems/configure --enable-maintainer-mode --prefix=/home/chengsn/RTEMS/MVME6100/RTEMS/rtems-5 --target=powerpc-rtems5 --enable-rtemsbsp=beatnik --enable-posix --enable-cxx --enable-networking --enable-tests
I also added rtems-libbspext to RTEMS5.
Then, I built EPICS7 like this:
$ cd ~/RTEMS/MVME6100/EPICS
$ wget https://epics.anl.gov/download/base/base-7.0.6.1.tar.gz.
$ tar Jxf base-7.0.6.1.tar.gz
$ cd base-7.0.6.1.tar.gz
And I changed some file:
$ vim configure/CONFIG_SITE
-CROSS_COMPILER_TARGET_ARCHS=
+CROSS_COMPILER_TARGET_ARCHS=RTEMS-beatnik
$ vim configure/os/CONFIG_SITE.Common.RTEMS
+RTEMS_VERSION = 5
+RTEMS_BASE = /home/chengsn/RTEMS/MVME6100/RTEMS/rtems-$(RTEMS_VERSION)
$ vim configure/os/CONFIG.Common.RTEMS-beatnik
+ARCH_DEP_CFLAGS += -DRTEMS_LEGACY_STACK
+ARCH_DEP_CFLAGS += -DBSP_NVRAM_BASE_ADDR=0xf1110000
Then,
$ make -j20
After I created an APP, I ran the bin/RTEMS-beatnik/timing.boot file on the MVME6100 and got the following output:
MVME6100> tftpGet -a4000000 -c10.1.201.21 -s10.1.201.31 -g10.1.201.1 -m255.255.255.0 -d/dev/enet0 -fmv6100/bin/RTEMS-beatnik/timing.boot
Network Loading from: /dev/enet0
Loading File: mv6100/bin/RTEMS-beatnik/timing.boot
Load Address: 04000000
Download Buffer Size = User Defined
Client IP Address = 10.1.201.21
Server IP Address = 10.1.201.31
Gateway IP Address = 10.1.201.1
Subnet IP Address Mask = 255.255.255.0
Network File Load in Progress...
Bytes Received =&5171112, Bytes Loaded =&5171112
Bytes/Second =&2585556, Elapsed Time =2 Second(s)
MVME6100> netShut
/dev/enet0 Disabled
/dev/enet1 Disabled
MVME6100> go -a4000000
config addr is 0xf1000cf8
config data is 0xf1000cfc
Welcome to RTEMS rtems-5.0.0 (PowerPC/Generic (classic FPU)/beatnik)
CPU: MPC7457
Board Type: MVME6100-0163 (S/N E045944)
Bus Clock Freq: 133333333 Hz
CPU Clock Freq: 1266666654 Hz
Memory: 536870912 bytes
Now BSP_mem_size = 0x1fe00000
Configuration.work_space_size = 201ac30
Page table setup finished; will activate it NOW...
Going to start PCI buses scanning and initialization
Number of PCI buses found is : 3
MSR 0x2003032
Exit from bspstart
unable to find the universe in pci config space
Tundra Tsi148 PCI-VME bridge detected at 0x81100000, IRQ 84
Tsi148 Outbound Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0e000000 0x90000000 A32, SUP, D32, SCT
1: 0x00000000 0x00ff0000 0x9f000000 A24, SUP, D32, SCT
2: 0x00000000 0x00010000 0x9fff0000 A16, SUP, D32, SCT
7: 0x00000000 0x01000000 0x9e000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0: 0x90000000 0x1fe00000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
Registering /dev/console as minor 0 (==/dev/ttyS0)
WARNING: OS Clock time was read before being set.
Using 1990-01-0
2 i0n0i:t0C0o:n0s0o.l0e0 0-0-0-0 IUnTfCo
stdin: fileno: 0, ttyname: /dev/console
stdout: fileno: 1, ttyname: /dev/console
stderr: fileno: 2, ttyname: /dev/console
time set to : 04/14/14 07:30:06.000000689 UTC
Startup.
epicsThreadSetPriority called by non epics thread
***** RTEMS Version: rtems-5.0.0 (PowerPC/Generic (classic FPU)/beatnik) *****
***** Initializing network (Legacy Stack) *****
Link detected; attaching mve1
bootpc_init: using network interface 'mve1'
bootpc hw address is 0:1:af:31:5e:76
BOOTP timeout for server 255.255.255.255
BOOTP call failed -- error 116BOOTP timeout for server 255.255.255.255
Even if I set some environment variables, there is no change:
mot-/dev/enet0-cipa= 10.1.201.21
mot-/dev/enet0-sipa= 10.1.201.31
mot-/dev/enet0-snma= 255.255.255.0
mot-/dev/enet0-file= mv6100/bin/RTEMS-beatnik/timing.boot
rtems-client-name= TEST0
epics-script= mv6100/st.cmd
I thought the function setBootConfigFromNVRAM()(in base/module/RTEMS/posix/rtems_init.c:952) does not work.
So I added some printf statements to see the value of the variable rtems_bsdnet_config.bootp:(the numbers 952 and 954 are the line numbers)
#ifdef RTEMS_LEGACY_STACK
if (epicsRtemsInitPreSetBootConfigFromNVRAM(&rtems_bsdnet_config) != 0)
delayedPanic("epicsRtemsInitPreSetBootConfigFromNVRAM");
+ printf("952-rtems_bsdnet_config.bootp:%x\n",rtems_bsdnet_config.bootp);
if (rtems_bsdnet_config.bootp == NULL) {
+ printf("954-rtems_bsdnet_config.bootp:%x\n",rtems_bsdnet_config.bootp);
extern void setBootConfigFromNVRAM(void);
setBootConfigFromNVRAM();
if (epicsRtemsInitPostSetBootConfigFromNVRAM(&rtems_bsdnet_config) != 0)
delayedPanic("epicsRtemsInitPostSetBootConfigFromNVRAM");
#endif
the OUTPUT:
Startup.
952-rtems_bsdnet_config.bootp:29740c
What should I do to solve this problem?
I do not know what is causing the BOOTP timeout.
Thank you!
chengsn
IHEP
