1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Timeout when running soft IOC as root
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Siddons, David" <[email protected]>
Date: Fri, 1 Jul 2022 11:29:46 -0700
On 6/30/22 13:07, Mooney, Tim M. wrote:
Hi Pete,
If you're using /dev/mem to read/write memory implemented in the FPGA using an AXI 4 peripheral, you may not have to write a driver, but may be able to use the generic-uio driver.  This allows access from a non-root account, and it allows access by name (which occurs in the device tree) instead of by address, which might change a become a pain in the neck.
I'll second this.  If you are only after memory mapped register access,
then using the "generic-uio" platform driver should be sufficient.
The main obsticle is understanding, and handling, linux device tree files.
I tried to lay out some of this back in 2020:
https://epics.anl.gov/tech-talk/2020/msg02201.php
Things do get more complicated if you want to make use of functionality
like interrupts or DMA.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
*From:* Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
*Sent:* Thursday, June 30, 2022 2:25 PM
*To:* Rivers, Mark L. <[email protected]>; Michael Davidsaver <[email protected]>
*Cc:* [email protected] <[email protected]>
*Subject:* Re: Timeout when running soft IOC as root
Hi Michael,
     You are right, of course. I am looking into getting a driver written, but it takes time.
Pete.
*From:* Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
*Sent:* Monday, June 27, 2022 9:12 PM
*To:* Mark Rivers <[email protected]>
On 6/27/22 10:24, Mark Rivers via Tech-talk wrote:
Folks,
I am trying to help Pete Siddons with a problem with an IOC that uses the quadEM module for a BPM he is developing.  It runs EPICS on a Zynq processor.  He says it was working on Debian 7, but is not working on Debian 11.
Which Linux kernel variant/version?
  Because the IOC talks to /dev/mem it needs to run as root.
ick...
I would very much recommend that Pete look at creating a real Linux driver.
mmap()ing "/dev/mem" into an userspace process is playing with fire.
Alternately, adjust file permissions and/or Linux kernel options to bypass
some /dev/mem safety checks (eg. STRICT_DEVMEM and IO_STRICT_DEVMEM)
https://urldefense.com/v3/__https://elixir.bootlin.com/linux/latest/source/lib/Kconfig.debug*L1804__;Iw!!P4SdNyxKAPE!FUgNGKi4r71uFnnc8bN6dWdAsVE564Lgzf5o-sG6kwN9Sen6WKDXYFqb3EbEpUN7LozrwhsWJrOZ-VqJllx9ig$ <https://urldefense.com/v3/__https://elixir.bootlin.com/linux/latest/source/lib/Kconfig.debug*L1804__;Iw!!P4SdNyxKAPE!FUgNGKi4r71uFnnc8bN6dWdAsVE564Lgzf5o-sG6kwN9Sen6WKDXYFqb3EbEpUN7LozrwhsWJrOZ-VqJllx9ig$>
The driver can be built in simulation mode, so it does not talk to the hardware at all.  In this mode the IOC runs fine when run as a non-privileged user, and takes a total of 3.5 seconds to start up.  This includes the time to create many areaDetector plugins.
However, when running as root there are timeout errors waiting for each of the plugin threads to be created.  The timeout is 2 seconds, and increasing it to 10 seconds does not fix the problem.
The quickest way to an answer will probably be gdb (or gdbserver).
Run with a break point set where the "timeout" message is printed[1].
When this is reached, dump all of the thread stacks. (run
"thread apply all backtrace")
This will show if the plugin threads are being created, and if so,
what they are doing.
[1] https://github.com/areaDetector/ADCore/blob/bcaced94ad48b9bb5fdbd1a7f6d9d8be5c416003/ADApp/pluginSrc/NDPluginDriver.cpp#L912 <https://github.com/areaDetector/ADCore/blob/bcaced94ad48b9bb5fdbd1a7f6d9d8be5c416003/ADApp/pluginSrc/NDPluginDriver.cpp#L912>
If you haven't encountered gdbserver before, there are two parts.
On the target run something like:
$ gdbserver 0.0.0.0:3333 ./bin/linux-arm/myioc st.cmd
Then on the (Debian) host run:
$ gdb-multiarch
(gdb) target extended-remote <target-ip>:3333
(gdb) b NDPluginDriver.cpp:912
(gdb) run
... wait for breakpoint
(gdb) thread apply all backtrace
... lots of output ...
(gdb) quit
The TCP port number can be anything.  3333 is an arbitrary choice.
This the abbreviated IOC startup output when not running as root.
date
2022/06/27 16:03:39.620634
errlogInit(5000)
< envPaths
epicsEnvSet("IOC","iocNSLS2_IC")
epicsEnvSet("TOP","/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4")
dbLoadDatabase("/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/dbd/quadEMTestApp.dbd")
quadEMTestApp_registerRecordDeviceDriver(pdbbase)
# The search path for database files
# Note: the separator between the path entries needs to be changed to a semicolon (;) on Windows
date
2022/06/27 16:03:39.953518
drvNSLS2_ICConfigure("NSLS2_IC", 0, 10000)
Memory mapped
Poller thread created
Creating parameters 0
Poll thread starts
Creating parameters 1
Creating parameters 2
Creating parameters 3
Creating parameters 4
Opening DACS
Getting firmware version
fpgabase=0x569a60
FPGA version=1001
Calling callbacks
date
2022/06/27 16:03:40.129864
# Create 11 statistics plugins
NDStatsConfigure("NSLS2_IC_STATS1", 20, 0, "NSLS2_IC", 0, 0, 0)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDStats.template",     "P=quadEMTest:,R=NSLS2_IC:Current1:, PORT=NSLS2_IC_STATS1, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC,NDARRAY_ADDR=0, HIST_SIZE=256,XSIZE=10000,YSIZE=0,NCHANS=1000,ENABLED=1,")
NDTimeSeriesConfigure("NSLS2_IC_STATS1_TS", 20, 0, "NSLS2_IC_STATS1", 1, 23)
NDFFTConfigure("NSLS2_IC_FFT11", 20, 0, "NSLS2_IC_TS1", 10)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:PosY:,PORT=NSLS2_IC_FFT11,ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=10,NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=PosY")
#< $(QUADEM)/iocBoot/saveRestore.cmd
date
2022/06/27 16:03:43.046352
iocInit()
## EPICS R7.0.6.1
## Rev. 2022-03-25T16:17+0000
Gain: 0
Setting bias voltage to 0.000000
date
2022/06/27 16:03:46.982984
# save settings every thirty seconds
#create_monitor_set("auto_settings.req",30,"P=$(PREFIX), R=$(RECORD)")
The IOC starts up fine.  The total time to start is about 3.5 seconds.  There are many plugin threads created during this time.
This the abbreviated IOC startup output when running as root.
date
2022/06/27 14:20:48.298214
errlogInit(5000)
< envPaths
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db:/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/db")
< /home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/iocBoot/iocNSLS2_IC/NSLS2_IC.cmd
date
2022/06/27 14:20:48.626216
Memory mapped
Poll thread starts
Opening DACS
fpgabase=0x5809b8
FPGA version=1001
Calling callbacks
date
2022/06/27 14:20:48.802463
< /home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/iocBoot/commonPlugins.cmd
# FFT plugins
NDFFTConfigure("NSLS2_IC_FFT1", 20, 0, "NSLS2_IC_TS1", 0)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current1:, PORT=NSLS2_IC_FFT1, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=0, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=Current1")
NDFFTConfigure("NSLS2_IC_FFT2", 20, 0, "NSLS2_IC_TS1", 1)
dbLoadRecords("/home/peter/epics/extensions/synApps/support2022/06/27 14:21:19.270 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:21:23.270 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:21:26.247 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:21:28.278 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
Starting iocInit
-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current2:, PORT=NSLS2_IC_FFT2, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=1, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP  MS,ENABLED=1,NAME=Current2")
NDFFTConfigure("NSLS2_IC_FFT3", 20, 0, "NSLS2_IC_TS1", 2
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current3:, PORT=NSLS2_IC_FFT3, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=2, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=Current3")
NDFFTConfigure("NSLS2_IC_FFT4", 20, 0, "NSLS2_IC_TS1", 3)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current4:, PORT=NSLS2_IC_FFT4, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=3, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=Current4")
NDFFTConfigure("NSLS2_IC_FFT5", 20, 0, "NSLS2_IC_TS1", 4)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumX:, PORT=NSLS2_IC_FFT5, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=4, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=SumX")
NDFFTConfigure("NSLS2_IC_FFT6", 20, 0, "NSLS2_IC_TS1", 5)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumY:, PORT=NSLS2_IC_FFT6, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=5, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=SumY")
NDFFTConfigure("NSLS2_IC_FFT7", 20, 0, "NSLS2_IC_TS1", 6)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumAll:, PORT=NSLS2_IC_FFT7, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=6, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=SumAll")
NDFFTConfigure("NSLS2_IC_FFT8", 20, 0, "NSLS2_IC_TS1", 7)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:DiffX:, PORT=NSLS2_IC_FFT8, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=7, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=DiffX")
NDFFTConfigure("NSLS2_IC_FFT9", 20, 0, "NSLS2_IC_TS1", 8)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:DiffY:, PORT=NSLS2_IC_FFT9, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=8, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=DiffY")
NDFFTConfigure("NSLS2_IC_FFT10", 20, 0, "NSLS2_IC_TS1", 9)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:PosX:,PORT=NSLS2_IC_FFT10,ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=9, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV  CP MS,ENABLED=1,NAME=PosX")
date
2022/06/27 14:21:29.253141
iocInit()
## EPICS R7.0.6.1
###########################2022/06/27 14:23:25.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:23:25.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:23:32.243 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:23:32.244 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:23:34.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS2_Plugin_1" to exit
was epicsThread object destroyed before thread exit ?
2022/06/27 14:24:05.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:24:08.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:24:08.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:24:08.241 quadEMTest:NSLS2_IC:Current2:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:24:10.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS2_TS_Plugin_1" to exit
2022/06/27 14:24:23.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:24:23.242 quadEMTest:NSLS2_IC:Current2:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:24:26.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:24:26.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:24:28.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:24:35.242 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:24:51.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:24:51.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:24:53.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:24:54.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:09.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:09.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:11.241 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS7_Plugin_1" to exit
2022/06/27 14:25:26.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:31.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:31.242 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:31.242 quadEMTest:NSLS2_IC:SumAll:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:25:34.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:34.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:36.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:25:40.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:43.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:43.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:43.243 quadEMTest:NSLS2_IC:DiffX:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:25:45.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:25:47.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:47.242 quadEMTest:NSLS2_IC:DiffX:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:25:50.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:50.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:52.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS9_Plugin_1" to exit
2022/06/27 14:26:04.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:07.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:07.248 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:07.249 quadEMTest:NSLS2_IC:DiffY:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:26:09.249 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:26:13.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:13.248 quadEMTest:NSLS2_IC:DiffY:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:26:24.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:24.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:26.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:26:35.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:38.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:38.249 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:38.249 quadEMTest:NSLS2_IC:PosY:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:26:40.250 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS11_TS_Plugin_1" to exit
2022/06/27 14:26:52.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:52.242 quadEMTest:NSLS2_IC:PosY:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:26:55.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:55.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:55.243 quadEMTest:NSLS2_IC:image1:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:26:57.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:27:01.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:01.242 quadEMTest:NSLS2_IC:image1:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:15.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:15.248 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:15.249 quadEMTest:NSLS2_IC:FFT:Current2:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:23.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:23.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:23.243 quadEMTest:NSLS2_IC:FFT:Current4:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:25.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:27:28.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:28.249 quadEMTest:NSLS2_IC:FFT:Current4:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:33.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:33.248 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:33.249 quadEMTest:NSLS2_IC:FFT:SumX:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:38.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:38.249 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:38.249 quadEMTest:NSLS2_IC:FFT:SumY:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:38.249 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:39.240 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:39.241 quadEMTest:NSLS2_IC:FFT:SumAll:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:41.243 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:41.244 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:41.244 quadEMTest:NSLS2_IC:FFT:SumAll:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:45.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:46.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:46.242 quadEMTest:NSLS2_IC:FFT:DiffY:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:47.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:48.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:48.242 quadEMTest:NSLS2_IC:FFT:PosX:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:49.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:50.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:50.244 quadEMTest:NSLS2_IC:FFT:PosY:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:53.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:56.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:59.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:02.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:05.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:08.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:11.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
Gain: 0
date
2022/06/27 14:32:29.293229
epics>
There are many errors waiting for plugin threads to start  (and then waiting for them to exit).  The total time to start is about 12 minutes compared to 3.5 seconds when not running as root.
Any ideas why there is an issue creating plugin threads when running as root, but not when running as a normal user?
Timeout when running soft IOC as root Mark Rivers via Tech-talk
Re: Timeout when running soft IOC as root Michael Davidsaver via Tech-talk
Re: Timeout when running soft IOC as root Siddons, David via Tech-talk
Re: Timeout when running soft IOC as root Mooney, Tim M. via Tech-talk
Prev: Re: Timeout when running soft IOC as root Mooney, Tim M. via Tech-talk
Next: Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100 Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Phoebus connection to alarm server / Kafka Ian Gillingham via Tech-talk
