1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: EPICS compilation errors
From: Adrian Martinez via Tech-talk <[email protected]>
Date: Fri, 8 Jul 2022 07:36:32 +0000
Hello Mark,
That is the driver code:
asynDrvr::asynDrvr( const char *portName, int index )
:EWBAsynPortDrvr( portName, MAX_NUM_SCOPE_PARAMS )
EWBBridge *pBgd;
pBgd = (EWBBridge*)new EWBBgdAXICon( WB2_ROOT_PERIPH_OFFSET, WB2_PERIPH_MAPPING_SIZE,
            WB2_PM_SLW_PERIPH_OFFSET, (uint32_t)WB2_PM_SLW_PERIPH_LAST, WB2_PM_SLW_BLOCKSIZE,
            WB2_PM_RAW_PERIPH_OFFSET, (uint32_t)WB2_PM_RAW_PERIPH_LAST, WB2_PM_RAW_BLOCKSIZE);
//Then define the root of the bus
pRoot = new EWBBus( pBgd, 0x0, NULL );
if(pRoot->isValid()==false){
printf("ERROR while creating pRoot!");
pPrhCtl   = NULL;
#ifdef _DEBUG
EWBTrace::getInstance().setLevel(EWBTrace::DEBUG);
#else
EWBTrace::getInstance().setLevel(EWBTrace::ERROR);
#endif
asynDrvr::~asynDrvr()
 // Setup
 // Setup for all the params needed in the driver. Create all the params included in each periph
asynStatus asynDrvr::setup()
AsynStatusObj status = asynSuccess;
setupEWBPeriphCtl();
syncTimeReg();
return status;
asynStatus asynDrvr::setupEWBPeriphCtl()
  EWBReg *lastreg;
pPrhCtl = new EWBPeriph(this->pRoot,WB2_PRH_ARGS( CTL ));
lastreg = new EWBReg( pPrhCtl, WB2_REG_ARGS( CTL, CTRL ));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, RSTSW )));
pPosMes = new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, POSMESENA ),0);
createParam( pPosMes );
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM ), 1), &idxAlarm , EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV); // TS3
pAcqst = new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ACQST ),0);
createParam( pAcqst );
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, USERBUFDUMP )), &idxDumpBuffer, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
pChannelCalib = new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, SELFCLBENA ));
createParam(pChannelCalib, &idxChannelCalib, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV | EWB_SYNC_FLG_PRE);
// createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, CABLECLBENA )), &idxCableCalib, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
pCableCalib = new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, CABLECLBENA ));
createParam( pCableCalib, &idxCableCalib, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, CNF_RDY )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, BPM_RDY )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_X )), &idxAlarmX, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_Y )), &idxAlarmY, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_I )), &idxAlarmI, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_P )), &idxAlarmP, EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_X_ACK )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_Y_ACK )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_I_ACK )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, ALARM_P_ACK )));
pIdle = new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, GET_IDLE ));
createParam( pIdle, &idxIdle );
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, CTRL, BPMSTATE )), &idxBpmState, EWB_SYNC_FLG_PRE | EWB_SYNC_FLG_POST | EWB_SYNC_FLG_DEV);
// Code to set the machine in Startup mode in each driver reboot
setIdle();
lastreg = new EWBReg( pPrhCtl, WB2_REG_ARGS( CTL, OVERAGE ));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, OVERAGE, ADC_TOP )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, OVERAGE, ADC_BOTTOM )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, OVERAGE, ADC_RIGHT )));
createParam( new EWBField( lastreg, WB2_FIELD_ARGS( CTL, OVERAGE, ADC_LEFT )));
createParam( "calibration_msg", asynParamOctet, &idxCalibrationMsg );
setStringParam( idxCalibrationMsg, "Please, select calibration to calibrate the system" );
createParam( "reset_calibration", asynParamInt32, &idxResetCalibration);
setIntegerParam( idxResetCalibration, 1 );
createParam( "Cavity_present", asynParamInt32, &idxCavityPresent);
setIntegerParam( idxCavityPresent, 0 );
createParam( "disable_calibration", asynParamInt32, &idxDisableCalibration);
setIntegerParam( idxDisableCalibration, 1);
createParam( "nfs_status", asynParamInt32);
// This PV allow to enable-disable the coupling compensation, using caput command
createParam( "enable_compensation", asynParamInt32, &idxEnableCompensation);
setIntegerParam( idxEnableCompensation, 0 );
createParam( "ntp_status", asynParamInt32 );
return status;
In addition to this, the driver code contains other functions such as postWriteFromPv(), preReadToPv(), postReadToPv()... used to execute diferrent conditions depending on the PVs flags.
Do you need any other part of the code?
Thanks, Adrián.
De: Mark Rivers <[email protected]>
Enviado: jueves, 7 de julio de 2022 16:05
Para: Adrian Martinez <[email protected]>
Asunto: RE: EPICS compilation errors
CAUTION: This email originated from outside of the organization.
Do not click links or open attachments unless you recognize the sender and know the content is safe.
Hi Adrian,
2022/07/06 10:46:59.429 asynPortDriver:drvUserCreate: addr=0, cannot find parameter Ctrl_RstSw
SL-SCL-CM3:DIA-BPM-3:ResetSoftStat devAsynInt32::initCommon drvUserCreate
This error is not shown for all the PVs and not always for the same PVs. For example, the first compilation shows error for PV1, PV2 and PV3, and the second compilation (immediately) shows error for PV2, PV4 and PV5.
Summing up, it is almost impossible to compile with 0 errors.
First, let me clarify.  Those are not compile errors, they are errors at run time, almost certainly during iocInit when the record is being initialized.
This sounds like a race condition where not all parameters have been created before iocInit is called.
Your driver should be creating all of the parameters in the constructor, which will run in the main thread of the startup script.  It is OK if createParam() is called in another function that is called from the constructor, but if it is done in another thread then the constructor must wait for that thread to complete.
It would probably be helpful if you shared your driver code so we could look for the problem.
From: Tech-talk <[email protected]> On Behalf Of Adrian Martinez via Tech-talk
Sent: Thursday, July 7, 2022 2:39 AM
To: [email protected]
Subject: EPICS compilation errors
Hello,
I am developing an epics driver using epics-3.15.5 and asyn-4-33. The driver works correctly but, sometimes (aprox 90% of the time), returns an error when the procces variables (PV) are initialized:
This error is not shown for all the PVs and not always for the same PVs. For example, the first compilation shows error for PV1, PV2 and PV3, and the second compilation (immediately) shows error for PV2, PV4 and PV5. Summing up, it is almost impossible to compile with 0 errors.
These errors just affect to PV readbacks, which never change its values, although the value can be read correctly in the memory register corresponding to the modified PV.
The error could be related with the asynPortDriver class so, createParam function from asynPortDriver.cpp it is working correctly, creating the param list with all PVs (it has been checked using a for loop after each createParam invocation):
Last createParam invocation to add mrf_time PV
PUSH = mrf_time
VALS[0] = Ctrl_RstSw
VALS[1] = Ctrl_PosMesEna
VALS[2] = Ctrl_Alarm
VALS[3] = Ctrl_Acqst
VALS[4] = Ctrl_UserBufDump
VALS[5] = Ctrl_SelfClbEna
VALS[6] = Ctrl_CableClbEna
VALS[7] = Ctrl_cnf_rdy
VALS[8] = Ctrl_bpm_rdy
VALS[9] = Ctrl_alarm_x
VALS[10] = Ctrl_alarm_y
VALS[11] = Ctrl_alarm_i
VALS[12] = Ctrl_alarm_p
VALS[13] = Ctrl_alarm_x_ack
VALS[14] = Ctrl_alarm_y_ack
VALS[15] = Ctrl_alarm_i_ack
VALS[16] = Ctrl_alarm_p_ack
VALS[17] = Ctrl_get_idle
VALS[18] = Ctrl_BpmState
VALS[19] = overage_adc_top
VALS[20] = overage_adc_bottom
VALS[21] = overage_adc_right
VALS[22] = overage_adc_left
VALS[23] = calibration_msg
VALS[24] = reset_calibration
VALS[25] = Cavity_present
VALS[26] = disable_calibration
VALS[27] = nfs_status
VALS[28] = enable_compensation
VALS[29] = ntp_status
VALS[30] = ctl_pps_utc_sw
VALS[31] = syncTimeMode
VALS[32] = mrf_time
VALS.SIZE() = 33
The problem comes when drvUserCreate() function is invocated and check all the PVs included in the param list.
/** Called by asynManager to pass a pasynUser structure and drvInfo string to the driver;
* Assigns pasynUser->reason based on the value of the drvInfo string.
* This base class implementation looks up the drvInfo string in the parameter list.
* \param[in] pasynUser pasynUser structure that driver will modify
* \param[in] drvInfo String containing information about what driver function is being referenced
* \param[out] pptypeName Location in which driver can write information.
* \param[out] psize Location where driver can write information about size of pptypeName */
asynStatus asynPortDriver::drvUserCreate(asynUser *pasynUser,
const char *drvInfo,
const char **pptypeName, size_t *psize)
static const char *functionName = "drvUserCreate";
asynStatus status;
int index;
int addr;
status = getAddress(pasynUser, &addr); if (status != asynSuccess) return(status);
status = this->findParam(addr, drvInfo, &index); // ¡¡¡ERROR!!!
if (status) {
asynPrint(pasynUser, ASYN_TRACE_ERROR,
"%s:%s: addr=%d, cannot find parameter %s\n",
driverName, functionName, addr, drvInfo);
return(status);
pasynUser->reason = index;
asynPrint(pasynUser, ASYN_TRACE_FLOW,
"%s:%s: drvInfo=%s, index=%d\n",
driverName, functionName, drvInfo, index);
return(asynSuccess);
findParam() is not able to find all the PVs and the if statement is executed. I have print each index after the findParam() execution and the param list has not all the PVs, missing just the ones not found.
Thanks in advance, Adrián.
Re: EPICS compilation errors Mark Rivers via Tech-talk
EPICS compilation errors Adrian Martinez via Tech-talk
RE: EPICS compilation errors Mark Rivers via Tech-talk
Prev: Re: Set/get enum value of mbbo from within AD driver Gofron, Kazimierz via Tech-talk
Next: Re: EPICS compilation errors Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: EPICS compilation errors Mark Rivers via Tech-talk
