1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Teledyne Dalsa Areadetector Driver
To: EPICS tech-talk <[email protected]>, Sandeep Kumar Malu - STFC UKRI <[email protected]>
Date: Tue, 12 Jul 2022 12:58:18 +0000
Hi Sandeep,
I looked at the documentation for the Teledyne Dalsa Radicon 3030 and unfortunately it does not appear to be GenICam compliant.  If it were, you could probably use ADAravis.
I would not recommend the ADCameraLink driver.  The author is no longer supporting it, and I don't think it is in wide use or well tested.
If no one else has written a driver I think you will need to write your own using their Sapera SDK.
From: Tech-talk <[email protected]> on behalf of Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
Sent: Monday, July 11, 2022 11:09 PM
Subject: Teledyne Dalsa Areadetector Driver
Hi All,
I am looking for Areadetector Driver for Teledyne Dalsa (Model - Radicon 3030) camera and wondering if anyone have already developed one. I see ADCameraLink  can be compiled for Dalsa Frame grabber. If anyone has developed camera specific driver for the same and can share would be of great help.
FYI, I do have all the relevant software licenses.
Many Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Teledyne Dalsa Areadetector Driver Sandeep Kumar Malu - STFC UKRI via Tech-talk
Prev: Re: Issue with Asyn+StreamDevice on a Raspi CM4 Mark Rivers via Tech-talk
Next: Re: Teledyne Dalsa Areadetector Driver David Vine via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Teledyne Dalsa Areadetector Driver Sandeep Kumar Malu - STFC UKRI via Tech-talk
