1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: motor driver only works with asyn traces turned on
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
Date: Fri, 15 Jul 2022 10:20:59 +0000
Hi Michael,
Does additionally adding an epicsThreadSleep() to writeController() make any difference?
Freddie
From: Tech-talk <[email protected]> On Behalf Of Sintschuk, Michael via Tech-talk
Sent: 15 July 2022 10:15
Subject: AW: motor driver only works with asyn traces turned on
Hi Mark,
1)      I added asynSetTraceFile to put the output to a file. The driver doesn’t work with that either and I don’t see any indication where the communication fails. I once got the output
2022/07/15 10:33:50.096 asynOctetSyncIO wrote:
M)_able.VAL",16777215,0,"$(P)$(M)_able.VAL")
#! Record("$(P)$(M)_vCh",440,699,0,
              but I don’t know what the means and it is not reproducible.
2)      I‘ve also overridden the writeReadController method and went up to epicsThreadSleep(0.5). I can see how the communication is slowed down but it doesn’t help.
I noticed that it is enough to comment in only the line
asynSetTraceMask("serial1",0,0x3)
and everything works fine. Except for the annoying IOC-console output…
Michael
Von: Mark Rivers <[email protected]>
Gesendet: Donnerstag, 14.
Juli 2022 19:22
An: Sintschuk, Michael <[email protected]>
Betreff: RE: motor driver only works with asyn traces turned on
SICHERHEITSHINWEIS: Diese E-Mail wurde von außerhalb an die BAM gesendet. Bitte klicken Sie nicht auf Links oder öffnen Anhänge, bevor Sie nicht den Absender verifiziert haben und sicher sind, dass der Inhalt vertrauenswürdig ist.
This message was sent from outside of BAM. Please do not click links or open attachments unless you recognize the sender and know the content is trustworthy.
Hi Michael,
Ø  BUT, it only works when asyn traces are turned on at IOC startup:
That indicates the problem is a timing issue.  When you enable asynTrace you slow down the execution of the program a little bit, which eliminates the timing problem.
My first guess would be that your controller is not able to accept commands quite as fast as they are sent when you disable asynTrace.
Here are the things I would suggest.
Add this line to you startup script after line 20:
asynSetTraceFile("serial1",0,"PS10.txt")
That will put the asynTrace output into the file PS10.txt.  If you are lucky writing the file will be faster than sending the trace output to the console, and the driver will not work.  That might let you see where the communication is messing up.
Another suggestion would be to override the asynMotorController::writeReadController method in your PS10Controller class, but add an epicsThreadSleep() after calling pasynOctetSyncIO->writeRead.  That might fix the problem.  Here is an example:
/** Writes a string to the controller and reads a response.
  * \param[in] output Pointer to the output string.
  * \param[out] input Pointer to the input string location.
  * \param[in] maxChars Size of the input buffer.
  * \param[out] nread Number of characters read.
  * \param[out] timeout Timeout before returning an error.*/
asynStatus PS10Controller::writeReadController(const char *output, char *input,
                                                    size_t maxChars, size_t *nread, double timeout)
  size_t nwrite;
  asynStatus status;
  int eomReason;
  // const char *functionName="writeReadController";
  status = pasynOctetSyncIO->writeRead(pasynUserController_, output,
                                       strlen(output), input, maxChars, timeout,
                                       &nwrite, nread, &eomReason);
  epicsThreadSleep(0.05);
  return status;
Sent: Thursday, July 14, 2022 9:56 AM
To:
[email protected]
Subject: motor driver only works with asyn traces turned on
Hi EPICS-community,
I’m trying to write a model 3 motor driver for ps 10 controller from OWIS. So far I made some good progress and I can move/stop the connected rotation stage (stepper motor, no encoder), also setting the velocity and running a homing sequence is possible.
asynSetTraceIOMask("serial1",0,0x1)
If I comment them out, the move command doesn’t work after IOC start. The Retry counts count until 11 and that’s it. The only thing that works is the homing sequence.
Did someone experienced such a behavior before? Do I have some obvious mistake somewhere in the driver-code?
I uploaded the code to git: https://github.com/MichaS-git/motorOwis
Regards
Michael
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
motor driver only works with asyn traces turned on Sintschuk, Michael via Tech-talk
RE: motor driver only works with asyn traces turned on Mark Rivers via Tech-talk
AW: motor driver only works with asyn traces turned on Sintschuk, Michael via Tech-talk
Prev: AW: motor driver only works with asyn traces turned on Sintschuk, Michael via Tech-talk
Next: AW: motor driver only works with asyn traces turned on Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
