1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Equivalent of EPICS_CA_NAME_SERVERS for PV Access?
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Gibbs, Matt" <[email protected]>
Date: Fri, 15 Jul 2022 19:35:34 +0000
EPICS_PVA_NAME_SERVERS works with PVXS (pvxget, pvxmonitor, ..) and the gateway based on PVXS: https://github.com/mdavidsaver/pvxs/, https://mdavidsaver.github.io/p4p/gw.html
It also works with the new Java PVA client (CS-Studio phoebus, https://github.com/ControlSystemStudio/phoebus/ can also used from matlab, https://github.com/ControlSystemStudio/phoebus/tree/master/core/pva).
It has not been ported to the older C++ and Java code, so the EPICS IOCs, Area Detector PVA plugins, ImageJ etc. won't support it.
The primary reason for using EPICS_PVA_NAME_SERVERS might however be the gateway, since it's easier to reach TCP via firewalls etc., so you can use the new gateway for that and the IOCs behind the gateway won't know anything about it.
For a client to the gateway you'll have to use CS-Studio or something else that uses the new C++ or Java client libs.
-Kay
From: Tech-talk <[email protected]> on behalf of Gibbs, Matt via Tech-talk <[email protected]>
Sent: Friday, July 15, 2022 2:10 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Equivalent of EPICS_CA_NAME_SERVERS for PV Access?
Hi all,
I often use the EPICS_CA_NAME_SERVERS environment variable to tell my CA client to do PV discovery on one specific hostname (usually a CA gateway server).
I’d like to be able to do the same thing for PV Access as well.  I’ve tried the naive approach of just setting “EPICS_PVA_NAME_SERVERS”, but that doesn’t seem to work.  Is there some other way to do the same thing?
—Matt
Equivalent of EPICS_CA_NAME_SERVERS for PV Access? Gibbs, Matt via Tech-talk
Prev: Equivalent of EPICS_CA_NAME_SERVERS for PV Access? Gibbs, Matt via Tech-talk
Next: Automatically populating the Archive Appliance Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
