1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: StreamDevice issues (Genesys power supply, Moxa)
Date: Mon, 25 Jul 2022 18:50:11 +0000
Hello,
I’m having trouble using StreamDevice to communicate with a TDK Lambda Genesys 30-110 power supply that’s talking to a Moxa NPort 6000 Series terminal server. We are running the same asyn code on another model, the Genesys 50-200, but it has no issue talking to a Moxa or a Digi.
When my IOC sends “ADR 06” to the 30-110 all at once, the power supply returns “C01” (illegal command or query), but when I enter the same command manually using telnet, I get “OK” as expected. I also get “OK” if I use asynInterposeDelay and a slow scan rate.
However, when my IOC sends this command as one string to a Digi terminal server, I also get “OK”. Is there any reason why I need to use asynInterposeDelay when using one terminal server but not for another?
We have a network person looking at the configuration of the terminal servers, but the basic web interface parameters are quite similar. In the meantime, do you have any suggestions?
An Le
SLAC National Accelerator Laboratory
Re: StreamDevice issues (Genesys power supply, Moxa) Zimoch Dirk (PSI) via Tech-talk
Prev: Accelerator Controls Software Position At Fermilab Dennis J. Nicklaus via Tech-talk
Next: Re: [EXTERNAL] Mimicking EVENT across IOCs Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: StreamDevice issues (Genesys power supply, Moxa) Zimoch Dirk (PSI) via Tech-talk
