1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: PINI field not working with modbus
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jul 2022 18:49:46 +0000
Adding a few things i found out, if it helps in anything:
I added
> asynSetTraceMask NEG_EMODBUS_1_1_Rd_VTarget -1 9
To the end of my st.cmd file. The resulting behavior is not what i expected. When i set my record to
record(ai, "${BL}:${H}:${EQ}:TargetVoltRead"){
    field(DESC, "Voltage set on target [V].")
    field(DTYP, "asynInt32")
    field(EGU, "V")
    field(ASLO, 0.01)
    field(INP, "@asyn(NEG_EMODBUS_1_1_Rd_VTarget,0,1000)MODBUS_DATA")
    field(SCAN, "1 second")
    field(PINI, "YES")
    field(PRIO, "LOW")
i run the st.cmd and get constant 1-second-periodic updates such as:
#create_monitor_set("/usr/local/epics/apps/config/NEG/NEG_save_restore.req", 5, "BL=${BL}, H=${H}, EQ=${EQ}")
## Start any sequence programs
#seq sncxxx,"user=gabrielfedelHost"
epics> 2022/07/26 18:41:18.535 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/26 18:41:18.535 drvModbusAsyn::readInt32 port NEG_EMODBUS_1_1_Rd_VTarget function=0x3, offset=00, value=0x4b0
2022/07/26 18:41:19.114 drvModbusAsyn::readInt32 port NEG_EMODBUS_1_1_Rd_VTarget function=0x3, offset=00, value=0x4b0
2022/07/26 18:41:19.583 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/26 18:41:20.114 drvModbusAsyn::readInt32 port NEG_EMODBUS_1_1_Rd_VTarget function=0x3, offset=00, value=0x4b0
2022/07/26 18:41:20.631 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
and so on...
However, when i change my record scan to "Passive", i still get 1-second-periodic updates, but now in the format:
epics> 2022/07/26 18:44:34.525 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/26 18:44:35.567 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/26 18:44:36.602 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/26 18:44:37.650 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
2022/07/26 18:44:38.697 drvModbusAsyn::doModbusIO port NEG_EMODBUS_1_1_Rd_VTarget READ_REGISTERS
even if the PINI field is in Passive. Am i supposed to receive this message every second even though there is no scan for this record? And it seems the modbus function was never actually called. Why is that?
Thanks for the help,
Marco
From: Marco A. Barra Montevechi Filho <[email protected]>
Sent: 26 July 2022 11:09
To: Mark Rivers <[email protected]>; [email protected] <[email protected]>
Of course!
it is defined in the st.cmd as:
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_VTarget", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x3000,1,0,${MBUS_POLL}, "");
I append the full st.cmd file below. I also tried to define other functions PINI to YES and FNLK to "${BL}:${H}:${EQ}:TargetVoltRead", but to no avail.
Any suggestions on how to improve the st.cmd are also welcome.
#!/home/marco/work/cnpem_git/LCI/NEGPowerMINI/bin/linux-x86_64/NEG
< /home/marco/work/cnpem_git/LCI/NEGPowerMINI/iocBoot/iocNEG/envPaths
epicsEnvSet("BL","LCI")
epicsEnvSet("H","X")
epicsEnvSet("EQ","NEGPowerMINI")
epicsEnvSet("IOCNAME","NEG")
# Configuração da linha de luz
< /home/marco/work/cnpem_git/LCI/NEGPowerMINI/iocBoot/iocNEG/NEG.config
epicsEnvSet("STREAM_PROTOCOL_PATH","${TOP}/db")
cd ${TOP}
dbLoadDatabase "dbd/NEG.dbd"
NEG_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("EMODBUS","10.20.41.90:502",0,0,1)
########NOT USED ANYMORE. KEEPING FOR HISTORICAL REASONS###
# Set up ASYN HYPPIE ports
# pxiCreateSM(asyn, shared memory name)
# drvasynPXIConfig(port, COM port, shared memory name, serial type)
#asynSetOption("EMODBUS", 0, "${BAUD}", "9600")
#asynSetOption("EMODBUS", 0, "bits", "8")
#asynSetOption("EMODBUS", 0, "parity", "none")
#asynSetOption("EMODBUS", 0, "stop", "1")
## Configure
modbusInterposeConfig("EMODBUS",0,3000,0)
# drvModbusAsynConfigure(portName,      => create a name
#                       tcpPortName,    => defined before
#                       slaveAddress,   => defined on equipament
#                       modbusFunction, => 3 : Read Holding Register (16-bit)
#                       modbusStartAddress, => adress of register
#                       modbusLength,  => the length of data segment
#                       dataType,  => default data type
#                       pollMsec,
#                       plcType);     => Equipament name, not used
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_SoftwareVersion", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ}, 0x1000, 1,    2, ${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_HardwareVersion", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x1002,1,2,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_PowerSuppIntState", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2000,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_LoggingState", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2001,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_SysUptime", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2002,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_InternalTemperature", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2004,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_PumpTemperature", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2005,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_OutVolt", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2006,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_OutCurr", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2007,1,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_TimeRunning", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x2008,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_Alarms", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200A,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_TempAlarms", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200C,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Rd_WorkTime", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_READ},0x200E,2,0,${MBUS_POLL}, "");
drvModbusAsynConfigure("NEG_EMODBUS_1_1_Wr_VTarget", "EMODBUS", ${MBUS_SL_ADDR},${MBUS_WRITE},0x3000,1,0,${MBUS_POLL}, "");
## Load record instances
dbLoadRecords("db/dbNEG.db", "BL=${BL}, H=${H}, EQ=${EQ}")
cd ${TOP}/iocBoot/${IOC}
iocInit
Thanks for the help 🙂
Marco
Sent: 26 July 2022 10:33
To: [email protected] <[email protected]>; Marco A. Barra Montevechi Filho <[email protected]>
Hi Marco,
Can you show us how the NEG_EMODBUS_1_1_Rd_VTarget port is configured?
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Tuesday, July 26, 2022 7:45 AM
Subject: PINI field not working with modbus
Hello all.
I have an analog in record for reading a modbus register from a device. The record is defined as follows:
    field(EGU, "V")
    field(ASLO, 0.01)
Which reads fine. However, if i set the PINI field to YES and the scan to passive:
    field(EGU, "V")
    field(ASLO, 0.01)
    field(SCAN, "Passive")
    field(PINI, "YES")
i get only 0 as value when cagetting the PV. Am i doing something wrong?
Thanks in advance.
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
RE: PINI field not working with modbus Mark Rivers via Tech-talk
PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Re: PINI field not working with modbus Mark Rivers via Tech-talk
Re: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Prev: Re: Delta Tau issue Lazarski, Krzysztof Z. via Tech-talk
Next: RE: PINI field not working with modbus Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
