1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: cagateway question
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 28 Jul 2022 09:31:11 +0200
Hello Geyang,
On Thu, 28 Jul 2022 at 09:18, Silver via Tech-talk <[email protected]> wrote:
I have a test ca gateway server which works well. Now I want to convert PVs from "tttaiExample1,tttaiExample2..." to "gtai1, gtai2...". I followed the example file, simply use ALIAS function in pvlist like this:
tttaiExample\([0-9]\) ALIAS gtai\1
but can't get the pv value of gtai1, gtai2.
what's the reason? it should work.
If you look at the documentation in the example configuration (https://github.com/epics-extensions/ca-gateway/blob/master/example/GATEWAY.pvlist), you will see that the ALIAS command generally looks like "new-name ALIAS existing-name" - your configuration seems to do it in the wrong order.
Cheers,
~Ralph
cagateway question Silver via Tech-talk
Prev: cagateway question Silver via Tech-talk
Next: RE: Delta Tau issue Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: EPICS Archiver Appliance - Auto-delete Old Data Rebecca Harding - STFC UKRI via Tech-talk
