1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Way to know when streamReload has been completed
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 2 Aug 2022 17:08:12 +0000
Hi all,
I've been using streamReload in both the IOC shell and inside an aSub function.  I have noticed that as streamReload executes, it causes a message to appear in the IOC Shell listing which records have just been reloaded. When the messages stop, I assume that is when streamReload has completed. I was wondering if there was a way to know when it has completed through a function of some sort that returns a value corresponding to the state of streamReload. The reason I ask is because if the operator does proceed with using streamReload on the Control Systems GUI, I would like there to be an indicator that shows grey when streamReload is executing and green when it has completed.
Thank you,
Andy
Prev: Re: streamdevice in command only 2048 length Mark Rivers via Tech-talk
Next: Way to know when streamReload has been completed Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
