Andrew, i finally tested your suggestion and indeed it works as you said: i was overwriting my A field with the calculation results.
It seems i misunderstood the transform record functionality, but its clear now. Thanks!
On 8/4/22 10:58 AM, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Wait, i think im still having difficulties with the transform record:
i have a record defined as:
record(transform, "${BL}:${H}:${EQ}:StatusSeparator"){
field(DESC, "PV to process status bitmask")
field(COPT, "Always")
field(SCAN, "1 second")
field(INPA, "${BL}:${H}:${EQ}:StatusBitmask")
field(CLCA, "A&1")
field(OUTA, "${BL}:${H}:${EQ}:EnableStatus")
And it behaves as expected: dbpf StatusBitmask 1 makes StatusSeparator.A field go to 1. Any other value in StatusBitmask that i tried makes StatusSeparator go to 0.
Now if i add field(CLCB, "A&1") to the record, dbpf StatusBitmask 1 makes both StatusSeparator.A and StatusSeparator.B go to 1. Ok, makes sense.
Now if i change CLCB to "A&2", then dbpf StatusBitmask 1 makes dbgf StatusSeparator.A return 1 and dbgf StatusSeparator.B return 0. Makes sense: bitwise AND between 1 and 2 is 0.
The curious thing now: dbpf StatusBitmask 2 makes dbgf StatusSeparator.A return 0 (makes sense: 1&2=0) and dbgf StatusSeparator.B return 0. This doesnt make sense to me since 2&2=2.
Am i doing something wrong?
If I understand it correctly, the result of CLCA gets written back to the A field, overwriting the 2 that was read in with 0, so the CLCB _expression_ is now 0&2 which is 0.
Don't set CLCA at all, start with CLCB, or use a different INP field for the status input bits. You probably don't need to set COPT at all if you do that.
- Andrew
Thanks, Tim! Thats exactly what was missing, the record works as expected now.
Apparently i was looking at another documentation page which does not have the COPT field specification:
https://epics.anl.gov/bcda/synApps/calc/R2-4/transformRecord.html
This page has it:
https://epics.anl.gov/bcda/synApps/calc/transformRecord.html
Best regards,
Marco
Versions earlier than 5.8 did not have the COPT field. Release notes Versions earlier than 5.7 did not post fields with the DBE_LOG attribute. Versions earlier than 5.6 expected sCalcPostfix to allocate the postfix-_expression_
array. sCalcPostfix no longer does this, and the transform record changed as a consequence.
epics.anl.gov
Hi Marco,
I think you need to look at the transform record's COPT field. To serve the original purpose of the record, CLCA is not performed if A has changed since the last time the record was processed. The non-default behavior you want requires that you set COPT to
"Always"
Good morning, all!
Im trying to implement the transform field in an IOC but im not getting the expected result:
i have an analog in record reading a bitmask value from a modbus register. Since the bitmask has 16 bits, i want to perform 16 bitwise operations to transform each bit in a
binary in record thus transforming each 0 or 1 into a different string.
Since i dont want to need to create 16 calcout records, i thought i could use the
transform record to perform all bitwise operations and push each one of them into a different
binary in record. So after reading the documentation i tried to perform a calculation with
transform just for testing:
record(ai,
"${BL}:${H}:${EQ}:BitmaskGetter")
field(DESC,
"Bitmask used by other pvs.")
field(DTYP,"asynInt32")
field(INP,"@asyn(SIP_EMODBUS_1_1_Rd_Status,0,1000)MODBUS_DATA")
field(SCAN, "I/O Intr")
field(FLNK,
record(transform,
field(DESC,
field(INPA,
field(CLCA,
"A+1")
field(OUTA,
field(SCAN,
"Passive")
record(bi,
"${BL}:${H}:${EQ}:EnableStatus"){
field(DESC,
"Power supply status")
field(ZNAM,
"Stopped")
field(ONAM,
"Started")
So i expected that while caget in BitmaskGetter returns 0, caget into StatusSeparator.A would return 1 and EnableStatus would return "Started". It is not what happens: StatusSeparator returns 0 and EnableStatus returns "Stopped".
To test if the calculation is right, i tried substituting the transform record to a
calc one:
record(ai,
field(DESC,
field(FLNK,
"test_calc")
record(calcout,
"${BL}:${H}:${EQ}:StatusSeparator""){
field(DESC,
field(INPA,
field(CALC,
"A+1")
field(OUT,
record(bi,
field(DESC,
field(ZNAM,
"Stopped")
field(ONAM,
"Started")
And now caget into StatusSeparator returns 1, StatusSeparator.A returns 0, BitmaskGetter returns 0 and EnableStatus returns "Started", as expected.
So i figure field OUTA from the transform record pushes the value in field A (which is zero) to the EnableStatus link. If this is the case, is there any way at all to push the result from CLCA to the EnableStatus link? Also,in which field is the
result from CLCA field stored, if any?
Thanks in advance,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta
ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying
to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Complexity comes for free, Simplicity you have to work for.
