1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: EPICS for a small lab - overkill?
From: John Dobbins via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Sean Leavey - STFC UKRI <[email protected]>
Date: Wed, 17 Aug 2022 19:43:29 +0000
My two cents:
If you are already familiar with EPICS (or have support from people who are) I would say sure.
If you will be using existing device support, that is another point on the plus side.
If you are learning EPICS , Control System Studio, the Archiver Appliance, the Alarm Server, it might not be worth the time invested.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
From: Tech-talk <[email protected]> on behalf of Sean Leavey - STFC UKRI via Tech-talk <[email protected]>
Sent: Wednesday, August 17, 2022 3:26 PM
To: [email protected] <[email protected]>
Subject: EPICS for a small lab - overkill?
Hi all,
I'm trying to determine the feasibility of using EPICS for simple monitoring of a small clean room facility. We'll need to read out various sensors (particle counters, temperature, etc.) via Modbus over Ethernet and archive the data at low speed (a few times per minute maybe) and also ideally display live data to lab users on a GUI (e.g. MEDM or modern equivalents). We're probably going to have a small number of outputs as well: automated switching of lights, fans, motors, that kind of thing. Maybe some alarms for e.g. triggering a warning light if particle counts get too high. No closed loops.
We could probably just use LabVIEW or similar but I don't like it much and prefer a licence-free and open source solution that can be easily adapted as needed. Plus, I may clone the EPICS setup to a different lab in a different city that we work with, so it would be nice to be able to use a gateway to access and archive their channels as well.
Has anyone used EPICS on such a small scale? Was it more trouble than it was worth compared to turnkey commercial solutions?
Any input would be appreciated!
Sean Leavey
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Prev: Re: EPICS for a small lab - overkill? Arnold, Ned D. via Tech-talk
Next: Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: EPICS for a small lab - overkill? Pete Jemian via Tech-talk
