1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: EPICS for a small lab - overkill?
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Sean Leavey - STFC UKRI <[email protected]>
Date: Wed, 17 Aug 2022 15:43:28 -0500
On 08/17, Sean Leavey - STFC UKRI via Tech-talk wrote:
> > Sounds reasonable to me!
> Great. Do you have any recommendations on how the single box should be set up? I saw some Docker images but not sure it's worth the effort over just building from source manually. I'd probably opt for Debian because that's what I know best. I'd put the IOC on the same box as the base, and use the Modbus support that I think is baked in already.
Hi, Sean!
I'm not a fan of Docker or any similar containerization system.  I'd
just put everything into a version control system so that you can manage
changes well.  If you like Debian, I'd go for an Ubuntu LTS release.
I've been happy with RHEL, and the license doesn't cost that much.  But
if you don't want to pay for the license, I'd check out Rocky Linux (but
I don't have any actual experience with it).
Lewis
EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Re: EPICS for a small lab - overkill? Arnold, Ned D. via Tech-talk
Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Prev: Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Next: Re: EPICS for a small lab - overkill? Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
