1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: olog docker question
To: tech-talk <[email protected]>
Date: Thu, 18 Aug 2022 16:36:26 +0800
hi,
I followed steps in https://github.com/Olog/phoebus-olog, but seems there are some problems. Is there any suggestions? Thanks a lot.
docker ps -a shows followings:
CONTAINER ID   IMAGE                  COMMAND                   CREATED         STATUS                     PORTS                                                 NAMES
4b3dac1118da   phoebus-olog_olog      "/bin/bash -c '\n    …"   9 minutes ago   Exited (1) 2 seconds ago                                                         phoebus-olog_olog_1
48f60797a68e   elasticsearch:6.8.13   "/usr/local/bin/dock…"    9 minutes ago   Up About a minute          0.0.0.0:9200->9200/tcp, :::9200->9200/tcp, 9300/tcp   phoebus-olog_elastic_1
74915fa11527   mongo                  "docker-entrypoint.s…"    9 minutes ago   Up About a minute          0.0.0.0:27017->27017/tcp, :::27017->27017/tcp         phoebus-olog_mongo_1
docker-compose up shows followings:
olog_1     | {
olog_1     |   "name" : "FpR4UNb",
olog_1     |   "cluster_name" : "elasticsearch",
olog_1     |   "cluster_uuid" : "vY8FYa4MTki3yPCenV1Uww",
olog_1     |   "version" : {
olog_1     |     "number" : "6.8.13",
olog_1     |     "build_flavor" : "default",
olog_1     |     "build_type" : "docker",
olog_1     |     "build_hash" : "be13c69",
olog_1     |     "build_date" : "2020-10-16T09:09:46.555371Z",
olog_1     |     "build_snapshot" : false,
olog_1     |     "lucene_version" : "7.7.3",
olog_1     |     "minimum_wire_compatibility_version" : "5.6.0",
olog_1     |     "minimum_index_compatibility_version" : "5.0.0"
olog_1     |   },
olog_1     |   "tagline" : "You Know, for Search"
olog_1     | }
olog_1     | no main manifest attribute, in service-olog-2.0.8-SNAPSHOT-javadoc.jar
phoebus-olog_olog_1 exited with code 1
mongo_1    | {"t":{"$date":"2022-08-18T08:29:32.353+00:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"Checkpointer","msg":"WiredTiger message","attr":{"message":"[1660811372:352992][1:0x7fc1570d2700], WT_SESSION.checkpoint: [WT_VERB_CHECKPOINT_PROGRESS] saving checkpoint snapshot min: 3, snapshot max: 3 snapshot count: 0, oldest timestamp: (0, 0) , meta checkpoint timestamp: (0, 0) base write gen: 19"}}
mongo_1    | {"t":{"$date":"2022-08-18T08:30:32.372+00:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"Checkpointer","msg":"WiredTiger message","attr":{"message":"[1660811432:372904][1:0x7fc1570d2700], WT_SESSION.checkpoint: [WT_VERB_CHECKPOINT_PROGRESS] saving checkpoint snapshot min: 6, snapshot max: 6 snapshot count: 0, oldest timestamp: (0, 0) , meta checkpoint timestamp: (0, 0) base write gen: 19"}}
mongo_1    | {"t":{"$date":"2022-08-18T08:31:32.390+00:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"Checkpointer","msg":"WiredTiger message","attr":{"message":"[1660811492:390721][1:0x7fc1570d2700], WT_SESSION.checkpoint: [WT_VERB_CHECKPOINT_PROGRESS] saving checkpoint snapshot min: 8, snapshot max: 8 snapshot count: 0, oldest timestamp: (0, 0) , meta checkpoint timestamp: (0, 0) base write gen: 19"}}
mongo_1    | {"t":{"$date":"2022-08-18T08:32:32.404+00:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"Checkpointer","msg":"WiredTiger message","attr":{"message":"[1660811552:404809][1:0x7fc1570d2700], WT_SESSION.checkpoint: [WT_VERB_CHECKPOINT_PROGRESS] saving checkpoint snapshot min: 10, snapshot max: 10 snapshot count: 0, oldest timestamp: (0, 0) , meta checkpoint timestamp: (0, 0) base write gen: 19"}}
Best wishes
Geyang 2022-08-18
Prev: RE: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Next: Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS for a small lab - overkill? boj via Tech-talk
Next: make release freezes terminal in synApps installation Marco A. Barra Montevechi Filho via Tech-talk
