1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Tue, 23 Aug 2022 18:40:51 -0700
On 8/23/22 18:22, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Hello all.
Im trying to compile areaDetector-R3-7 in my machine. After following this tutorial: (https://areadetector.github.io/master/install_guide.html <https://areadetector.github.io/master/install_guide.html>) and turning every WITH_GRAPHICSMAGICK variable to NO to avoid problems with VP8LDelete and similar functions, im facing the compiling error that i append in the end of this email. It seems to be originated in areaDetector-R3-7/ADCore/ADApp/pluginSrc.
Searching for answers i found this answer: (https://epics.anl.gov/tech-talk/2017/msg00990.php <https://epics.anl.gov/tech-talk/2017/msg00990.php>) but i dont think its the same as my problem since EPICS_BASE is correctly defined in my configure/RELEASE_LIBS.local, configure/RELEASE_BASE.local and configure/RELEASE_PRODS.local. My version of areaDetector also didnt come with the files EXAMPLE_RELEASE_PATHS.local and EXAMPLE_CONFIG_SITE.local.
Does anyone have any hints on how to proceed? Thanks in advance.
Which version of EPICS Base are you building with?
Compilation message when done inside areaDetector-R3-7/ADCore/ADApp/pluginSrc:
Do you see the same with ADCore R3-9 ?
areaDetector-R3-7/ADCore/ADApp/pluginSrc$ make
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
     T_A=linux-x86_64 install
make[1]: Entering directory '/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADCore/ADApp/pluginSrc/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall    -DHAVE_JPEG -DHAVE_BLOSC -DHAVE_BITSHUFFLE -DH5_NO_DEPRECATED_SYMBOLS -DH5Gopen_vers=2  -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/marco/EPICS/synApps_6_1/support/asyn-R4-36/include     -I/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/marco/EPICS/epics-base/include/compiler/gcc -I/home/marco/EPICS/epics-base/include/os/Linux -I/home/marco/EPICS/epics-base/include        -c ../NDArrayRing.cpp
In file included from ../../../include/NDArray.h:20,
                  from ../NDArrayRing.h:4,
                  from ../NDArrayRing.cpp:19:
../../../include/NDAttribute.h:87:23: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type
    87 | class epicsShareClass NDAttribute {
../../../include/NDAttribute.h:88:1: error: expected primary-expression before ‘public’
    88 | public:
../../../include/NDAttribute.h:88:1: error: expected ‘}’ before ‘public’
../../../include/NDAttribute.h:87:35: note: to match this ‘{’
../../../include/NDAttribute.h:88:1: error: expected ‘,’ or ‘;’ before ‘public’
    88 | public:
../../../include/NDAttribute.h:92:16: error: expected constructor, destructor, or type conversion before ‘(’ token
    92 |     NDAttribute(NDAttribute& attribute);
../../../include/NDAttribute.h:94:13: error: declaration of ‘~ NDAttribute’ as non-member
    94 |     virtual ~NDAttribute();
../../../include/NDAttribute.h:95:13: error: ‘NDAttribute’ does not name a type
    95 |     virtual NDAttribute* copy(NDAttribute *pAttribute);
../../../include/NDAttribute.h:96:5: error: ‘virtual’ outside class declaration
    96 |     virtual const char *getName();
../../../include/NDAttribute.h:97:5: error: ‘virtual’ outside class declaration
    97 |     virtual const char *getDescription();
../../../include/NDAttribute.h:98:5: error: ‘virtual’ outside class declaration
    98 |     virtual const char *getSource();
../../../include/NDAttribute.h:99:5: error: ‘virtual’ outside class declaration
    99 |     virtual const char *getSourceInfo(NDAttrSource_t *pSourceType);
../../../include/NDAttribute.h:100:5: error: ‘virtual’ outside class declaration
   100 |     virtual NDAttrDataType_t getDataType();
../../../include/NDAttribute.h:101:5: error: ‘virtual’ outside class declaration
   101 |     virtual int getValueInfo(NDAttrDataType_t *pDataType, size_t *pDataSize);
../../../include/NDAttribute.h:102:5: error: ‘virtual’ outside class declaration
   102 |     virtual int getValue(NDAttrDataType_t dataType, void *pValue, size_t dataSize=0);
../../../include/NDAttribute.h:103:5: error: ‘virtual’ outside class declaration
   103 |     virtual int getValue(std::string& value);
../../../include/NDAttribute.h:104:5: error: ‘virtual’ outside class declaration
   104 |     virtual int setDataType(NDAttrDataType_t dataType);
../../../include/NDAttribute.h:105:5: error: ‘virtual’ outside class declaration
   105 |     virtual int setValue(const void *pValue);
../../../include/NDAttribute.h:106:5: error: ‘virtual’ outside class declaration
   106 |     virtual int setValue(const std::string&);
../../../include/NDAttribute.h:107:5: error: ‘virtual’ outside class declaration
   107 |     virtual int updateValue();
../../../include/NDAttribute.h:108:5: error: ‘virtual’ outside class declaration
   108 |     virtual int report(FILE *fp, int details);
../../../include/NDAttribute.h:109:5: error: ‘friend’ used outside of class
   109 |     friend class NDArray;
../../../include/NDAttribute.h:110:5: error: ‘friend’ used outside of class
   110 |     friend class NDAttributeList;
../../../include/NDAttribute.h:113:1: error: expected unqualified-id before ‘private’
   113 | private:
../../../include/NDAttribute.h:124:1: error: expected declaration before ‘}’ token
   124 | };
In file included from ../../../include/NDArray.h:21,
../../../include/NDAttributeList.h:21:23: error: variable ‘epicsShareClass NDAttributeList’ has initializer but incomplete type
    21 | class epicsShareClass NDAttributeList {
../../../include/NDAttributeList.h:22:1: error: expected primary-expression before ‘public’
    22 | public:
../../../include/NDAttributeList.h:22:1: error: expected ‘}’ before ‘public’
../../../include/NDAttributeList.h:21:39: note: to match this ‘{’
../../../include/NDAttributeList.h:22:1: error: expected ‘,’ or ‘;’ before ‘public’
    22 | public:
../../../include/NDAttributeList.h:24:23: error: expected constructor, destructor, or type conversion before ‘;’ token
    24 |     ~NDAttributeList();
../../../include/NDAttributeList.h:25:35: error: ‘pAttribute’ was not declared in this scope; did you mean ‘NDAttribute’?
    25 |     int          add(NDAttribute *pAttribute);
       |                                   NDAttribute
../../../include/NDAttributeList.h:26:5: error: ‘NDAttribute’ does not name a type
    26 |     NDAttribute* add(const char *pName, const char *pDescription="",
../../../include/NDAttributeList.h:28:5: error: ‘NDAttribute’ does not name a type
    28 |     NDAttribute* find(const char *pName);
../../../include/NDAttributeList.h:29:5: error: ‘NDAttribute’ does not name a type
    29 |     NDAttribute* next(NDAttribute *pAttribute);
../../../include/NDAttributeList.h:33:40: error: ‘pOut’ was not declared in this scope
    33 |     int          copy(NDAttributeList *pOut);
../../../include/NDAttributeList.h:37:1: error: expected unqualified-id before ‘private’
    37 | private:
../../../include/NDAttributeList.h:40:1: error: expected declaration before ‘}’ token
    40 | };
In file included from ../NDArrayRing.h:4,
../../../include/NDArray.h:92:23: error: variable ‘epicsShareClass NDArray’ has initializer but incomplete type
    92 | class epicsShareClass NDArray {
../../../include/NDArray.h:93:1: error: expected primary-expression before ‘public’
    93 | public:
../../../include/NDArray.h:93:1: error: expected ‘}’ before ‘public’
../../../include/NDArray.h:92:31: note: to match this ‘{’
../../../include/NDArray.h:93:1: error: expected ‘,’ or ‘;’ before ‘public’
    93 | public:
../../../include/NDArray.h:96:90: error: expected constructor, destructor, or type conversion before ‘;’ token
    96 |     NDArray(int ndims, size_t *dims, NDDataType_t dataType, size_t dataSize, void *pData);
../../../include/NDArray.h:97:13: error: declaration of ‘~ NDArray’ as non-member
    97 |     virtual ~NDArray();
../../../include/NDArray.h:103:38: error: non-member function ‘int getReferenceCount()’ cannot have cv-qualifier
   103 |     int          getReferenceCount() const {return referenceCount;}
../../../include/NDArray.h: In function ‘int getReferenceCount()’:
../../../include/NDArray.h:103:52: error: ‘referenceCount’ was not declared in this scope; did you mean ‘getReferenceCount’?
       |                                                    getReferenceCount
../../../include/NDArray.h: At global scope:
../../../include/NDArray.h:105:5: error: ‘friend’ used outside of class
   105 |     friend class NDArrayPool;
../../../include/NDArray.h:107:1: error: expected unqualified-id before ‘private’
   107 | private:
../../../include/NDArray.h:111:1: error: expected unqualified-id before ‘public’
   111 | public:
../../../include/NDArray.h:127:5: error: ‘NDAttributeList’ does not name a type
   127 |     NDAttributeList *pAttributeList;  /**< Linked list of attributes */
../../../include/NDArray.h:130:1: error: expected declaration before ‘}’ token
   130 | };
../../../include/NDArray.h:142:32: error: expected ‘)’ before ‘*’ token
   142 |         freeListElement(NDArray *pArray, size_t dataSize) {
../../../include/NDArray.h:148:9: error: ‘NDArray’ does not name a type
   148 |         NDArray *pArray_;
../../../include/NDArray.h:161:23: error: variable ‘epicsShareClass NDArrayPool’ has initializer but incomplete type
   161 | class epicsShareClass NDArrayPool {
../../../include/NDArray.h:162:1: error: expected primary-expression before ‘public’
   162 | public:
../../../include/NDArray.h:162:1: error: expected ‘}’ before ‘public’
../../../include/NDArray.h:161:35: note: to match this ‘{’
../../../include/NDArray.h:162:1: error: expected ‘,’ or ‘;’ before ‘public’
   162 | public:
../../../include/NDArray.h:164:13: error: declaration of ‘~ NDArrayPool’ as non-member
   164 |     virtual ~NDArrayPool() {}
../../../include/NDArray.h:165:5: error: ‘NDArray’ does not name a type
   165 |     NDArray*     alloc(int ndims, size_t *dims, NDDataType_t dataType, size_t dataSize, void *pData);
../../../include/NDArray.h:166:5: error: ‘NDArray’ does not name a type
   166 |     NDArray*     copy(NDArray *pIn, NDArray *pOut, bool copyData, bool copyDimensions=true, bool copyDataType=true);
../../../include/NDArray.h:168:26: error: ‘int reserve’ redeclared as different kind of entity
   168 |     int          reserve(NDArray *pArray);
../../../include/NDArray.h:101:18: note: previous declaration ‘int reserve()’
   101 |     int          reserve();
../../../include/NDArray.h:168:35: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
       |                                   NDArray
../../../include/NDArray.h:169:26: error: ‘int release’ redeclared as different kind of entity
   169 |     int          release(NDArray *pArray);
../../../include/NDArray.h:102:18: note: previous declaration ‘int release()’
   102 |     int          release();
../../../include/NDArray.h:169:35: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
       |                                   NDArray
../../../include/NDArray.h:170:35: error: ‘pIn’ was not declared in this scope
   170 |     int          convert(NDArray *pIn,
../../../include/NDArray.h:171:36: error: ‘ppOut’ was not declared in this scope
   171 |                          NDArray **ppOut,
../../../include/NDArray.h:172:39: error: expected primary-expression before ‘dataTypeOut’
   172 |                          NDDataType_t dataTypeOut,
../../../include/NDArray.h:173:40: error: expected primary-expression before ‘*’ token
   173 |                          NDDimension_t *outDims);
../../../include/NDArray.h:173:41: error: ‘outDims’ was not declared in this scope
../../../include/NDArray.h:173:48: error: expression list treated as compound expression in initializer [-fpermissive]
../../../include/NDArray.h:174:18: error: redefinition of ‘int convert’
   174 |     int          convert(NDArray *pIn,
../../../include/NDArray.h:170:18: note: ‘int convert’ previously defined here
../../../include/NDArray.h:174:35: error: ‘pIn’ was not declared in this scope
../../../include/NDArray.h:175:36: error: ‘ppOut’ was not declared in this scope
   175 |                          NDArray **ppOut,
../../../include/NDArray.h:176:39: error: expected primary-expression before ‘dataTypeOut’
   176 |                          NDDataType_t dataTypeOut);
../../../include/NDArray.h:184:1: error: expected unqualified-id before ‘protected’
   184 | protected:
../../../include/NDArray.h:189:5: error: ‘virtual’ outside class declaration
   189 |     virtual void onAllocateArray(NDArray *pArray);
../../../include/NDArray.h:189:18: error: variable or field ‘onAllocateArray’ declared void
../../../include/NDArray.h:189:43: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
       |                                           NDArray
../../../include/NDArray.h:190:5: error: ‘virtual’ outside class declaration
   190 |     virtual void onReserveArray(NDArray *pArray);
../../../include/NDArray.h:190:18: error: variable or field ‘onReserveArray’ declared void
../../../include/NDArray.h:190:42: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
       |                                          NDArray
../../../include/NDArray.h:191:5: error: ‘virtual’ outside class declaration
   191 |     virtual void onReleaseArray(NDArray *pArray);
../../../include/NDArray.h:191:18: error: variable or field ‘onReleaseArray’ declared void
../../../include/NDArray.h:191:42: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
       |                                          NDArray
../../../include/NDArray.h:193:1: error: expected unqualified-id before ‘private’
   193 | private:
../../../include/NDArray.h:200:1: error: expected declaration before ‘}’ token
   200 | };
In file included from ../NDArrayRing.cpp:19:
../NDArrayRing.h:20:5: error: ‘NDArray’ does not name a type
    20 |     NDArray *addToEnd(NDArray *pArray);
../NDArrayRing.h:23:5: error: ‘NDArray’ does not name a type
    23 |     NDArray *readFromStart();
../NDArrayRing.h:26:5: error: ‘NDArray’ does not name a type
    26 |     NDArray *readNext();
../NDArrayRing.h:36:5: error: ‘NDArray’ does not name a type
    36 |     NDArray** buffers_;
../NDArrayRing.cpp: In constructor ‘NDArrayRing::NDArrayRing(int)’:
../NDArrayRing.cpp:24:3: error: ‘buffers_’ was not declared in this scope; did you mean ‘numBuffers_’?
    24 |   buffers_ = NULL;
       |   numBuffers_
../NDArrayRing.cpp:29:18: error: ‘NDArray’ does not name a type
    29 |   buffers_ = new NDArray *[noOfBuffers_];
../NDArrayRing.cpp:29:28: error: capture of non-variable ‘NDArrayRing::noOfBuffers_’
../NDArrayRing.h:39:10: note: ‘int NDArrayRing::noOfBuffers_’ declared here
    39 |     int  noOfBuffers_;
../NDArrayRing.cpp: In lambda function:
../NDArrayRing.cpp:29:41: error: expected ‘{’ before ‘;’ token
../NDArrayRing.cpp: In destructor ‘NDArrayRing::~NDArrayRing()’:
../NDArrayRing.cpp:38:12: error: ‘buffers_’ was not declared in this scope; did you mean ‘numBuffers_’?
    38 |   delete[] buffers_;
       |            numBuffers_
../NDArrayRing.cpp: At global scope:
../NDArrayRing.cpp:49:1: error: ‘NDArray’ does not name a type
    49 | NDArray *NDArrayRing::addToEnd(NDArray *pArray)
../NDArrayRing.cpp:71:1: error: ‘NDArray’ does not name a type
    71 | NDArray *NDArrayRing::readFromStart()
../NDArrayRing.cpp:83:1: error: ‘NDArray’ does not name a type
    83 | NDArray *NDArrayRing::readNext()
../NDArrayRing.cpp: In member function ‘void NDArrayRing::clear()’:
../NDArrayRing.cpp:104:7: error: ‘buffers_’ was not declared in this scope; did you mean ‘numBuffers_’?
   104 |   if (buffers_){
       |       numBuffers_
../../../include/NDAttribute.h: At global scope:
../../../include/NDAttribute.h:93:24: warning: ‘const char* attrSourceString(NDAttrSource_t)’ declared ‘static’ but never defined [-Wunused-function]
    93 |     static const char *attrSourceString(NDAttrSource_t type);
../../../include/NDArray.h:99:18: warning: ‘int computeArrayInfo(int, size_t*, NDDataType_t, NDArrayInfo*)’ declared ‘static’ but never defined [-Wunused-function]
    99 |     static int   computeArrayInfo(int ndims, size_t *dims, NDDataType_t dataType, NDArrayInfo *pInfo);
make[1]: *** [/home/marco/EPICS/epics-base/configure/RULES_BUILD:267: NDArrayRing.o] Error 1
make[1]: Leaving directory '/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADCore/ADApp/pluginSrc/O.linux-x86_64'
make: *** [/home/marco/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type Marco A. Barra Montevechi Filho via Tech-talk
Prev: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type Marco A. Barra Montevechi Filho via Tech-talk
