Thanks for sharing the source.
Can you post the errors you get when renaming the .c file to .cpp?
It looks like the C file is mainly a convenience function for creating the Modbus drivers. Most if not all of that could probably be done in the startup script instead. But I can see what needs to be done to make it work with the current version of the
Modbus driver.
Sent from my iPhone
Hi Mark,
unfortunately, it doesnt work, various casts fail.
I've saved a dump here:
https://gitlab.fhi.mpg.de/kw/eurotherm2k
(should be externally accessible)
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 26.08.22 um 14:40 schrieb Mark Rivers:
Hi William,
You can probably just rename eurothermModbus.c to
eurothermModbus.cpp. See if that works.
How does eurothermModbus use drvModbusAsyn?
From: Tech-talk on behalf of William Kirstaedter via Tech-talk
Sent: Friday, August 26, 2022 7:20 AM
To:
[email protected]
Subject: Eurotherm modbus support
unfortunately the DLS site for the eurotherm support module is not available anymore...
(http://controls.diamond.ac.uk/downloads/support/eurotherm2k/)
does anybody still maintain eurotherms?
I kinda converted the 1-22 release to work with my environment and am now running into a C / C++ error...
newer asyn versions reference vector.h which is C++ while my eurotherm support file is C, which is bad because the C compiler doesnt know about the C++ vector.h ...
In file included from /home/epics/EPICS/epics-support/modbus/include/drvModbusAsyn.h:15,
from ../eurothermModbus.c:25:
/home/epics/EPICS/epics-support/asyn/include/asynPortDriver.h:4:10: fatal error: vector: No such file or directory
#include <vector>
compilation terminated.
Im not sure how to get around this....
maybe someone with more experience in the EPICS build system can help me out.
thanks,
William
William Kirstaedter (PP&B) |
Fritz-Haber-Institut der MPG |
Faradayweg 4-6 |
14195 Berlin |
Tel: 030 8413 5405 |
Mail:
[email protected] |
- Re: Eurotherm modbus support Mark Rivers via Tech-talk
- Re: Eurotherm modbus support William Kirstaedter via Tech-talk
RE: Eurotherm modbus support Mark Rivers via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
