1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: EPICS on ESP32
From: Joel Sherrill via Tech-talk <[email protected]>
To: Eric Norum <[email protected]>
Date: Wed, 31 Aug 2022 13:09:57 -0500
Nice summary Eric. I'll add that in the FACE Technical Standard which tailors POSIX for safety critical avionics systems, all profiles include UDP while only the larger two include TCP. TCP is of higher complexity and harder to put through the verification processes required in some domains.
In fact, lwIP even includes a build option to disable TCP which is one of the factors in how it can be configured to be so small.
For those who haven't noticed, for RTEMS 6 you build RTEMS, then have a choice of libbsd, lwip, or the legacy stack. And Eric was the one who originally ported what is now the legacy stack.
--joel
On Wed, Aug 31, 2022 at 11:58 AM Eric Norum via Tech-talk <[email protected]> wrote:
The most important reason that UDP is more appropriate for basic command/reply operations is that it puts you in control of the retries.  You can keep track of how many times they are required and you can tune the retry timeouts as you wish.  For example, many of my ’network attached device’ UDP ASYN drivers work as follows:
  1. Send a command
  2. if a reply is not received in 100 ms then send the command again
  3. if a reply is not received in 1 second then send the command again  —  after 5 attempts report an error
Some other UDP advantages:
  • UDP is much simpler — direct implementation in FPGA firmware is quite feasible.
  • UDP has lower network overhead — in the absence of errors the only packets on the wire are the commands and replies.
  • UDP is connectionless — there’s no overhead in setting up communication nor the possibility of dangling resources on unexpected loss of an IOC (e.g. the IOC host crashes without closing all the TCP streams).
Although TCP is ‘reliable’ you still have to check the success of every I/O request so there’s really not much programming overhead needed when using UDP.
If you’re transferring very large amounts of data then TCP is likely easier to implement to provide high bandwidth, but in pretty much all other cases I’d recommend UDP.
On Aug 31, 2022, at 12:50 AM, Florian Feldbauer <[email protected]> wrote:
Thanks for all the feedback,
I have to admit I did not properly checked the memory of the chip compared to the requirements for an IOC.
And I also might have mixed up RTEMS with RTOS 😅
I guess I either stay with my current design (TCP socket on the module using StreamDevice + Asyn for communication with an external IOC) or I'll switch to ModbusTCP.
Btw Eric, why do you think UDP would be more appropriate than TCP?
Cheers,
Florian
Eric Norum
EPICS on ESP32 Florian Feldbauer via Tech-talk
Re: EPICS on ESP32 Eric Norum via Tech-talk
Re: EPICS on ESP32 Florian Feldbauer via Tech-talk
Prev: Re: EPICS on ESP32 Eric Norum via Tech-talk
Next: Re: EPICS on ESP32 Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
