1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: asyn build fail
From: "Siddons, David via Tech-talk" <[email protected]>
Date: Wed, 31 Aug 2022 18:56:22 +0000
I am provisioning a new machine (Ubuntu 22.04), and have installed and built base-3.15.9. I'm now installing synApps, and the build failed  when building asyn, see below:
make[3]: Entering directory '/home/peter/epics/synApps/support/asyn-R4-42/asyn/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API  -D_X86_64_ -DUNIX  -Dlinux     -O3   -Wall    -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC  -mtune=generic    -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/home/peter/epics/synApps/support/ipac-2-16/include   -I/home/peter/epics/synApps/support/seq-2-2-9/include -I/home/peter/epics/base-3.15.9/include/compiler/gcc -I/home/peter/epics/base-3.15.9/include/os/Linux -I/home/peter/epics/base-3.15.9/include        -c vxi11core_xdr.c
In file included from vxi11core_xdr.c:6:
vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
    9 | #include <rpc/rpc.h>
compilation terminated.
The file /usr/include/rpc/rpc.h does not exist. There is a file /usr/include/tirpc/rpc/rpc.h. Should I simply copy the files into /usr/include? Or edit the offending source files to point to these new locations?
Pete.
Re: asyn build fail Li, Ji via Tech-talk
Prev: Re: EPICS on ESP32 Eric Norum via Tech-talk
Next: Re: asyn build fail Li, Ji via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: Problem with DB_INSTALLS in Makefile Mark Rivers via Tech-talk
