1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: SPI-MAXNET8000
To: Kevin Peterson <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Sep 2022 14:50:41 +0000
I have fixed similar problems in the past by adding a 1 microfarad capacitor between each of the limit lines and the limit line common. That can be be done in the motor cable connector, for example.
Sent from my iPhone
> On Sep 2, 2022, at 9:45 AM, Kevin Peterson <[email protected]> wrote:
> When the EPICS support is working, if the motor records for SPI-MAXnet-8000 axes stop moving prematurely, there is noise on the limit lines.
> More info about the problem is here:
>  https://epics.anl.gov/tech-talk/2017/msg00243.php
> Kevin
SPI-MAXNET8000 hejian--- via Tech-talk
Re: SPI-MAXNET8000 Mark Rivers via Tech-talk
Re: SPI-MAXNET8000 Kevin Peterson via Tech-talk
Prev: Re: SPI-MAXNET8000 Kevin Peterson via Tech-talk
Next: Re: Re: SPI-MAXNET8000 hejian--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
