1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: 'CAS-client' failed in ../db/dbEvent.c line 540
To: Oleg Makarov <[email protected]>, "Jeffrey O. Hill" <[email protected]>, Ralph Lange <[email protected]>
Date: Tue, 6 Sep 2022 22:34:42 +0000
Ø  I am using the latest mv6100-dev7 vxWorks BS.
OK, I just wanted to make sure this was not related to the problem I was having with vxWorks memory page attributes.  That was fixed in –dev7.
Sent: Tuesday, September 6, 2022 5:32 PM
To: Mark Rivers <[email protected]>; Jeffrey O. Hill <[email protected]>; Ralph Lange <[email protected]>
Cc: [email protected]
Subject: Re: 'CAS-client' failed in ../db/dbEvent.c line 540
Mark,
Oleg
On 9/6/2022 3:48 PM, Mark Rivers wrote:
Hi Oleg,
What release of the vxWorks BSP are you using?  You can see with the “release” command at the vxWorks prompt.
From: Tech-talk <[email protected]> On Behalf Of Makarov, Oleg A. via Tech-talk
Sent: Tuesday, September 6, 2022 3:20 PM
To: Jeffrey O. Hill <[email protected]>; Ralph Lange <[email protected]>
Subject: 'CAS-client' failed in ../db/dbEvent.c line 540
Hi Jeffrey and Ralph,
I am observing occasional/intermittent error in the vxWorks EPICS IOC. Error occurs during connection from CA client to the PVs in the IOC.
mvme6100 IOC is running on EPICS version 7.0.6.1. We have CA clients using Java JCA library 2.4.1 and pyepics 3.5.0.
A call to 'assert(status == epicsMutexLockOK)'
    by thread 'CAS-client' failed in ../db/dbEvent.c line 540.
EPICS Release EPICS R7.0.6.1.
Local time is 2022-09-06 14:58:32.719904388 CST/CDT
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
Do you have any insights on how to avoid this error?
Thank you,
Oleg Makarov and Mark Hillgart
'CAS-client' failed in ../db/dbEvent.c line 540 Makarov, Oleg A. via Tech-talk
RE: 'CAS-client' failed in ../db/dbEvent.c line 540 Mark Rivers via Tech-talk
Re: 'CAS-client' failed in ../db/dbEvent.c line 540 Oleg Makarov via Tech-talk
Prev: Re: 'CAS-client' failed in ../db/dbEvent.c line 540 Oleg Makarov via Tech-talk
Next: Re: 'CAS-client' failed in ../db/dbEvent.c line 540 Oleg Makarov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: 'CAS-client' failed in ../db/dbEvent.c line 540 Michael Davidsaver via Tech-talk
