1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Error while building ADSupport module
From: Siddharth Vardhan Pratihast via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 13 Sep 2022 19:36:23 +0530
I am trying to build ADSupport module.
I have mentioned path for BASE in RELEASE file and then run 'make' command from TOP directory.
I got the following error:
/usr/bin/ld: libnanohttp_stream.so: hidden symbol `xmlStrdup__internal_alias' isn't defined
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
make[3]: *** [libnanohttp_stream.so] Error 1
make[3]: Leaving directory `/epics/support/ADSupport/supportApp/xml2Src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/epics/support/ADSupport/supportApp/xml2Src'
make[1]: *** [xml2Src.install] Error 2
make[1]: Leaving directory `/epics/support/ADSupport/supportApp'
make: *** [supportApp.install] Error 2
Do anyone have a clue about this?
Thanks in advance.
सिद्धार्थ वर्धन प्रतिहस्त / Siddharth Vardhan Pratihast
वैज्ञानिक अधिकारी / Scientific Officer
कंप्यूटर एवं सूचना वर्ग / Computer and Informatics Group
परिवर्ती उर्जा साइक्लोट्रॉन केंद्र / Variable Energy Cyclotron Centre
परमाणु उर्जा विभाग / Department of Atomic Energy
भारत सरकार / Government of India
1/ए एफ विधान नगर / 1/AF Bidhan Nagar
कोलकाता - 700064 , भारत / Kolkata - 700064, India
RE: Error while building ADSupport module Engbretson, Mark S. via Tech-talk
Prev: RE: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: [EXTERNAL] EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Ralph Lange via Tech-talk
Next: RE: Error while building ADSupport module Engbretson, Mark S. via Tech-talk
