1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Process a record only when IOC shell exits
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 15 Sep 2022 11:23:50 +0200
On Thu, 15 Sept 2022 at 09:50, Wang, Andrew via Tech-talk <[email protected]> wrote:
I am wondering if it is possible to have a record process only when the exit command is sent to the IOC Shell.
Have a look at the different options for the PINI field. That's probably as close as you can get without coding.
Cheers,
~Ralph
Re: Process a record only when IOC shell exits Andrew Johnson via Tech-talk
Process a record only when IOC shell exits Wang, Andrew via Tech-talk
Prev: Process a record only when IOC shell exits Wang, Andrew via Tech-talk
Next: Question regarding synApps:delaygen Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: Process a record only when IOC shell exits Andrew Johnson via Tech-talk
