1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>, Ralph Lange <[email protected]>
Date: Fri, 16 Sep 2022 12:38:16 +0000
>> If the epics clients use the broadcast address, wont that allow multiple IOCs to listen on the same host on windows?
> It's the other case (unicast to a host running multiple IOCs) where we have a workaround for a Linux host and it would be interesting to have something similar for Windows hosts.
Yes, you can use broadcasts.
The options in this example include
set EPICS_CA_ADDR_LIST=ca_gateway.bessy.de
set EPICS_CA_AUTO_ADDR_LIST=NO
-> You get PVs from the gateway, assuming the gateway hears you because it's the only CA server on that host.
set EPICS_CA_ADDR_LIST=my_computer.bessy.de
-> You get PVs from the IOC started last, since unicasts are only received by the listener registered last (or the one first for windows hosts??).
set EPICS_CA_ADDR_LIST=broadcast_address_of_the_subnet
-> All CA servers on the subnet get it, which might be both my_computer.bessy.de and ca_gateway.bessy.de. So you can't avoid the gateway. A gateway is often configured to be read-only, so depending on luck you might get a read-only PV via the gateway or a writable PV from the actual IOC. Ask me how many confused emails that has caused.
One solution to this is to run the gateway on a non-standard port like 5099, so then you can  use
-> All servers on the subnet get it, including multiple IOCs on my_computer.bessy.de, but not the gateway
set EPICS_CA_ADDR_LIST=ca_gateway.bessy.de:5099
-> Only the gateway will reply
.. or you get into the IP packet rewrite tricks mentioned earlier.
-Kay
Re: [EXTERNAL] Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Andrew Johnson via Tech-talk
EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Carsten Winkler via Tech-talk
Re: [EXTERNAL] EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Hartman, Steven via Tech-talk
Re: [EXTERNAL] EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Carsten Winkler via Tech-talk
Re: [EXTERNAL] EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Andrew Johnson via Tech-talk
RE: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Manoussakis, Adamandios via Tech-talk
Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Ralph Lange via Tech-talk
Prev: Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
